#141: wingrass native: Georectifier throws error if user completes form by typing
Reporter: RRosario | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: Tcl | Version: 6.3.0 RCs
Keywords: wingrass windows native output no such variable georectify |
In the dialog box that is displayed after Georectify is selected from the
File menu, if a user types in the information instead of clicking on the
labeled buttons to fill the fields, the following error is displayed:
Error: can't read "output": no such variable
Problem is resolved by using point-and-click to select the necessary
group, mapset and map raster.
Ticket URL: <http://trac.osgeo.org/grass/ticket/141>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies. GRASS is official project of the Open Source Geospatial Foundation.
Resolution: | Keywords: wingrass windows native output no such variable georectify
Comment (by 4everskiff):
Replying to [ticket:141 RRosario]:
the File menu, if a user types in the information instead of clicking on
the labeled buttons to fill the fields, the following error is displayed:
Could you please check it out with WinGRASS 6.3.0?
Thanks
Comment (by cmbarton):
Since my class is over, I don't have as many ways to test this on Windows.
I've tried it on my Mac and typing is no problem. What happens if you
press <return> after typing in a field?
Resolution: | Keywords: georectify, gis.m
Platform: Unspecified | Cpu: Unspecified
Changes (by hamish):
* keywords: wingrass windows native output no such variable georectify
=> georectify, gis.m
* platform: => Unspecified
* cpu: => Unspecified
Comment:
I can reproduce this in 6.4.0rc4 wingrass + 6.5svn on Linux.
- File -> Georectify
- Click in "select mapset" box, type "foo"
- [tab] to "select group", type "bar"
- [tab] to "select map", type "baz"
- click [start georectifying] -> error window.
- click [ok] GCP table opens as expected
full error message is:
while executing
"puts $output "# Ground Control Points File""
(procedure "GRMap::savegcp" line 17)
invoked from within
"GRMap::savegcp"
(procedure "GRMap::gcp_error" line 24)
invoked from within
"GRMap::gcp_error"
(procedure "GRMap::gcpwin" line 121)
invoked from within
"GRMap::gcpwin"
(procedure "GRMap::refmap" line 33)
invoked from within
"GRMap::refmap"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .grstart.mf.frame.start.a"
(command bound to event)
