[GRASS-dev] [GRASS GIS] #1411: closing area boundary crashes entire GUI
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: wxdigizer,digitizer | Platform: Unspecified
      Cpu: OSX/Intel |
If I'm creating an area in the wxGUI digitizer, right clicking to close
the boundary (how else to close it?) will crash the GUI. This is on the
Mac, but may affect other platforms. GRASS 7 compiled a couple days ago
(r47225)
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411&gt;
Reporter: cmbarton | Owner: martinl
     Type: defect | Status: assigned
      Cpu: OSX/Intel |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Comment:
* 32 or 64bit ?
  * compiled with or without LFS?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:1&gt;
Priority: critical | Milestone: 6.5.0
Component: wxGUI | Version: unspecified
      Cpu: OSX/Intel |
Changes (by cmbarton):
  * version: svn-trunk => unspecified
  * milestone: 7.0.0 => 6.5.0
Comment:
This affects both GRASS 7 and GRASS 6.5
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:2&gt;
      Cpu: OSX/Intel |
Comment(by martinl):
Replying to [comment:2 cmbarton]:
...and probably also 6.4.2. It's seems to me as a know bug (if you are on
32bits and with LFS).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:3&gt;
      Cpu: OSX/Intel |
Comment(by cmbarton):
I'm on a Mac. This is compiled 64bit and without LFS support (unless that
is the default). Here is my config string:
./configure --with-freetype --with-freetype-
includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2
/Library/Frameworks/FreeType.framework/unix/include" --with-freetype-
libs=/Library/Frameworks/FreeType.framework/unix/lib --with-
gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj
--with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include
--with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-
share=/Library/Frameworks/PROJ.framework/Resources/proj --with-
geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-jpeg-
includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-
jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-
png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-
tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo
--with-cairo-
includes="/Library/Frameworks/cairo.framework/unix/include/cairo
/Library/Frameworks/cairo.framework/unix/include" --with-cairo-
libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-
ldflags="-lcairo" --without-postgres --without-mysql --with-odbc --with-
sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib
--with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include
--with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include
--with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x
--with-cxx --with-opengl=aqua --without-readline
--prefix=/Applications/GRASS --enable-macosx-app --with-python --with-
wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.0/bin/wx-config --with-
tcltk-includes="/Library/Frameworks/Tcl.framework/Headers
/Library/Frameworks/Tk.framework/Headers
/Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-
libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386 x86_64"
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:4&gt;
      Cpu: OSX/Intel |
Old description:
(r47225)
Michael
New description:
(r47225)
Michael'' ''
try more recent version please. Also some debug messages could help
g.gisenv set=DEBUG=5
and attach last debug messages you obtain.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:5&gt;
      Cpu: OSX/Intel |
Closing an area feature in the digitizer now works fine. No crashes.
Thanks much!
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:6&gt;
      Cpu: OSX/Intel |
Tested in GRASS 7 compiled a few minutes ago 12 Sept. 2011.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:7&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wxdigizer,digitizer
  Platform: Unspecified | Cpu: OSX/Intel
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1411#comment:8&gt;
