[GRASS-dev] [GRASS GIS] #1415: closecell: can't move + quant file error in winGRASS Msys shell
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Default | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
      Cpu: Unspecified |
Running v.surf.bspline in the MSys shell leads to a quant file error (in
the wxGUI command console no such problem!):
v.surf.bspline input=ahn5m raster=ahn5m_interp sie=15
sin=15 method=bicubic lambda_i=0.05
No vector map of sparse points to interpolate was specified.
Interpolation will be done with <ahn5m> vector map
subregion 1 of 6
subregion 2 of 6
subregion 3 of 6
subregion 4 of 6
subregion 5 of 6
subregion 6 of 6
closecell: can't move C:\Users\yaraya\Documents\GIS
DataBase/meuse/PERMANENT/.tmp/1964.0
to cell file C:\Users\yaraya\Documents\GIS
DataBase/meuse/PERMANENT/fcell/ahn5m_interp
Cannot write quant rules: map ahn5m_interp is integer
unable to write quant file!
v.surf.bspline complete.
The white space in the path seems to trigger the problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1415&gt;
      Cpu: Unspecified |
Changes (by neteler):
* cc: lenoir.john@… (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1415#comment:1&gt;
Component: Vector | Version: svn-releasebranch64
Keywords: v.surf.bspline, wingrass | Platform: MSWindows XP
      Cpu: Unspecified |
Changes (by hamish):
  * keywords: => v.surf.bspline, wingrass
  * component: Default => Vector
Comment:
do you still see this in the latest nightly build of native wingrass
6.5svn? (maybe wait for tomorrow's build)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1415#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.surf.bspline, wingrass
  Platform: MSWindows XP | Cpu: Unspecified
  * status: new => closed
  * resolution: => fixed
Comment:
No more problems reported, closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1415#comment:3&gt;
