#1417: Error during Grass start
Reporter: RazorCharlie | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: 6.4.1 RCs
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
Just after GRASS installatin during Grass start I got a problem.
I can't start Grass having error message:
Unable to get current geografic extent. Force quiting
wxGUI[[Image(D:\Soft\GRASS_GIS_Setup\Error_duringGrassStart.jpg)]]
Keywords: g.region | Platform: MSWindows XP
Cpu: x86-32 |
Description changed by martinl:
Old description:
New description:
Unable to get current geografic extent. Force quiting wxGUI.
Cpu: x86-32 |
Comment(by martinl):
Replying to [comment:6 RazorCharlie]:
> g.region -p says:
> "The ordinal 284 coul not be located in the dynamic link library
SSLEAY32.dll",
> see attached files
Cpu: x86-32 |
Comment(by hellik):
> g.region -p says:
SSLEAY32.dll",
> see attached files
Cpu: x86-32 |
Comment(by razorcharlie):
Replying to [comment:8 hellik]:
> > g.region -p says:
SSLEAY32.dll",
> > see attached files
> please try one of the latest nightly builds of wingrass64svn
> http://wingrass.fsv.cvut.cz/grass64/
> best regards
> Helmut
Just before your answer I have installed QGIS (QGIS-
OSGeo4W-1.7.0-b55a00e73-Setup.exe) from http://www.qgis.org/. During it's
installation additional Visual C++ libraries were installed. Strange but
it solved the problem with GRASS start!
I haven't tried new builds yet because it seems that all works as it
should do.
Thank you for your assistance!
fwiw, on a new install of the 6.4.2rc3 stand-alone package I needed to
download and install msvcp71.dll before it would run. (earlier version of
the same didn't need that)
