GDAL
August 21, 2011, 9:08pm
1
#1426: v.colors resetting vector display
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: v.colors | Platform: Unspecified
Cpu: Unspecified |
v.colors seems to reset all vector settings to default. If you have set
the symbol type and size, for example, running v.colors resets it to a 5
point "x".
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
August 24, 2011, 5:08pm
2
Cpu: Unspecified |
Comment(by martinl):
I don't fully understand, eg.
d.vect bridges size=10 icon=basic/box
OK
v.colors bridges color=ryg
OK
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:1> ;
GDAL
August 24, 2011, 8:44pm
3
Cpu: Unspecified |
Comment(by cmbarton):
OK
Update display screen (without running d.vect again). size reverts to 5
and icon reverts to basic/x
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:2> ;
GDAL
August 24, 2011, 9:11pm
4
Cpu: Unspecified |
Replying to [comment:2 cmbarton]:
are you referring to wxGUI or monitors ({{{d.mon}}})?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:3> ;
GDAL
August 24, 2011, 9:47pm
5
Cpu: Unspecified |
wxgui
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:4> ;
GDAL
August 25, 2011, 9:08am
6
Cpu: Unspecified |
Replying to [comment:4 cmbarton]:
> wxgui
* start wxgui
* add vector map 'bridges' (no color table defined)
* set size to '10' and icon to 'basic/box'
* re-render, OK
* launch `v.colors` and set color table to `byr`
* re-render, OK, symbols are boxes with size of 10
Right?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:5> ;
GDAL
August 25, 2011, 5:08pm
7
Cpu: Unspecified |
Maybe it's happing if v.colors is run with rules=
This effect can be seen when setting color rules via colorrules.py
OnApply calls v.colors rules=[some rules], and then UpdateMap. When it
does, it resets all d.vect settings back to default except for the color.
If it is not v.colors. It is not UpdateMap that is causing this. The only
other command being run is v.colors rules=
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:6> ;
GDAL
August 25, 2011, 5:13pm
8
Cpu: Unspecified |
The same effect happens in the preview window. This is copying the vector
layer command from the layer tree and then running v.colors rules=
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:7> ;
GDAL
August 25, 2011, 5:18pm
9
Cpu: Unspecified |
Comment(by annakrat):
Yes, I can see where the problem is. I'll fix it tomorrow.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:8> ;
GDAL
August 25, 2011, 8:45pm
10
Cpu: Unspecified |
Thanks Anna.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:9> ;
GDAL
August 26, 2011, 12:46pm
11
Cpu: Unspecified |
This bug happens when using GRASSRGB column instead of color table. It
should be fixed (r47891). Still I'm not sure if this is the problem you
mean.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:10> ;
GDAL
August 26, 2011, 5:39pm
12
Cpu: Unspecified |
I'll test the revision. Thanks. It seems like something in v.colors was
running d.vect -a and it shouldn't do that. It should simply set the
colors.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:11> ;
GDAL
August 26, 2011, 6:36pm
13
Cpu: Unspecified |
Replying to [comment:11 cmbarton]:
colors.
`v.colors` cannot run `d.vect` itself, it' just modifying color table.
wxGUI wrapper runs `d.vect` for preview. Also note that `d.vect -a` is
required only for color rules stored in attribute table. If you set up
file-based color table, `d.vect` renders vector table colorized without
any flag.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:12> ;
GDAL
August 27, 2011, 3:31pm
14
Cpu: Unspecified |
This is fixed for the main display, though it would be nice if preview
also looked like the main display too. The only issue is that now, a 'no
color rules set' error is popping up when colorrules is launched and when
a field is selected to create color rules, even if the color rules
checkbox is not checked. Probably just needs a conditional for the error
check in CreatColorTable or to move the error check to another position.
Thanks much for the fix.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:13> ;
GDAL
August 27, 2011, 3:33pm
15
Component: wxGUI | Version: svn-trunk
Keywords: v.colors, colorrules | Platform: Unspecified
Cpu: Unspecified |
Changes (by martinl):
* keywords: v.colors => v.colors, colorrules
* component: Default => wxGUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:14> ;
GDAL
August 27, 2011, 5:35pm
16
Type: defect | Status: closed
Resolution: fixed | Keywords: v.colors, colorrules
Platform: Unspecified | Cpu: Unspecified
Changes (by cmbarton):
* status: new => closed
* resolution: => fixed
Comment:
I fixed the error message. The preview display is an enhancement request
for colorrules, not v.colors. So this is now fixed. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:15> ;
