#1430: Buffer overrun in vector/diglib dig__fread_port_L with big-endian negative
values on LP64 systems
Reporter: rroliver | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: svn-trunk
Keywords: diglib portable LP64 big-endian | Platform: Unspecified
Cpu: All |
The code in dig__fread_port_L is broken for handling big endian negative
numbers on systems where sizeof(long) != PORT_LONG.
Presently the code fails to negate the value and will write 4 bytes past
the end of the buffer.
Problem exists for all grass versions through to trunk...
Cpu: All |
Comment(by mmetz):
Replying to [ticket:1430 rroliver]:
> The code in dig!__fread_port_L is broken for handling big endian
negative numbers on systems where sizeof(long) != PORT_LONG.
The patch seems to make sense but there are more subtle bugs in
lib/diglib/portable.c related to big endian systems. Can you test grass7
(trunk)? I have applied your patch plus some more modifications in trunk
in r47992. After testing, they can be backported to 6.5. and 6.4.2.
Cpu: All |
Comment(by mmetz):
Replying to [comment:2 hamish]:
> Replying to mmetz in #2085:
> > It seems that r47992 needs to be backported (see also #1430).
> ok, I guess the portable.c part of r56890 wants backporting too?
Cpu: All |
Comment(by hamish):
Replying to [comment:3 mmetz]:
> Right, done in r57855,6.
a sincere thank you, but **please** let changes to the core libraries
prove themselves in devbr6 for a couple weeks before backporting into
relbr64.
Cpu: All |
Comment(by mmetz):
Replying to [comment:4 hamish]:
relbr64.
Apparently, this bug appeared in the official testing environment of
Debian with the officially included GRASS version 6.4.3 on big endian
hardware. I guess that it will take 3 - 4 years until my change will be
tested in the same testing environment (Debian on big endian hardware with
GRASS version 6.4.4, yet to be released and after that to be included into
Debian).
We know that GRASS 7 compiles successfully on big endian hardware with AIX
as OS. Therefore I am confident that my change will fix the reported bug.
It would be preferable if a GRASS developer would have access to big
endian hardware with Linux or BSD as OS and would regularly test svn
versions of GRASS on such a system.
Further more, I would like to see the development branch of GRASS to be
deleted.
Cpu: All |
Comment(by mmetz):
relbr64.
The change works in relbr64 with Fedora for ppc64. It seems that devbr6
will not get tested any time soon.
