#1431: r.sun segfault in mode 2
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Raster | Version: svn-releasebranch64
Keywords: | Platform: Linux
Cpu: x86-64 |
With the NC data set, this crashes:
GRASS 6.4.2svn (nc_spm_08):~ > g.region rast=elevation
GRASS 6.4.2svn (nc_spm_08):~ > r.sun elevin=elevation aspin=aspect
slopein=slope lat=36.107 day=75 beam_rad=b_rad.075 diff_rad=d_rad.075
refl_rad=r_rad.075
Mode 2: integrated daily irradiation for a given day of the year
Segmentation fault
Debugging output which looks like bad initialization:
GRASS 6.4.2svn (nc_spm_08):~ > gdb r.sun
GNU gdb (GDB) 7.1-1mdv2010.1 (Mandriva Linux release 2010.1)
(gdb) r elevin=elevation aspin=aspect slopein=slope lat=36.107 day=75
beam_rad=b_rad.075 diff_rad=d_rad.075 refl_rad=r_rad.075
Starting program: /home/neteler/grass64/dist.x86_64-unknown-linux-
gnu/bin/r.sun elevin=elevation aspin=aspect slopein=slope lat=36.107
day=75 beam_rad=b_rad.075 diff_rad=d_rad.075 refl_rad=r_rad.075
[Thread debugging using libthread_db enabled]
0%
Program received signal SIGSEGV, Segmentation fault.
pj_transform (srcdefn=0x0, dstdefn=0x0, point_count=1, point_offset=0,
x=0x7fffffffd0e0, y=0x7fffffffd0d8,
z=0x7fffffffd0d0) at pj_transform.c:98
98 if( srcdefn->is_geocent )
(gdb) bt full
#0 pj_transform (srcdefn=0x0, dstdefn=0x0, point_count=1, point_offset=0,
i = <value optimized out>
#1 0x00007ffff7bd9b26 in pj_do_proj (x=0x7fffffffd268, y=0x7fffffffd270,
info_in=0x60d760, info_out=0x60d7e0)
at do_proj.c:100
ok = 1092827616
u = 0
v = 0
h = 0
#2 0x00000000004080e1 in calculate (singleSlope=1.2135880960744616e-311,
singleAspect=3.6562339989189768e-319,
singleAlbedo=0.20000000000000001, singleLinke=3, gridGeom=...) at
main.c:1865
i = 1
j = 1
l = 1350
someRadiation = 1
numRows = 1350
arrayOffset = 1
lum = 6.9533488366228911e-310
q1 = 3.1829936871890069e-311
dayRad = 3.1514668911888089e-317
latid_l = 6.9533558072950894e-310
cos_u = 2.0779926761062822e-317
cos_v = 6.9533558073061565e-310
sin_u = 6.953349070413816e-310
sin_v = 0
sin_phi_l = 0
tan_lam_l = 0
zmax = 156.32986450195312
longitTime = 0
locTimeOffset = 1.4821969375237396e-323
latitude = 215010
longitude = 630010
coslat = 630000
sunGeom = {lum_C11 = 2.0969134140794186e-317, lum_C13 =
6.3691388397870058e-314,
lum_C22 = 6.9533488366228911e-310, lum_C31 =
6.9533491751815725e-310, lum_C33 = 6.9533558072603072e-310,
sunrise_time = 2.1219957904712067e-314, sunset_time =
timeAngle = 4.9406564584124654e-324, sindecl =
0.030294190998040194, cosdecl = 0.99954102566716807}
sunVarGeom = {isShadow = -11720, z_orig = 127.38738250732422, zmax
= 156.32986450195312, zp = 127.38738250732422,
solarAltitude = 0, sinSolarAltitude = 0, tanSolarAltitude =
6.9533488354035371e-310,
solarAzimuth = 6.9533490691820115e-310, sunAzimuthAngle =
6.9531436082559572e-310, stepsinangle = 0,
stepcosangle = 0}
sunSlopeGeom = {longit_l = 6.9533558072535879e-310, lum_C31_l =
2.1219957909652723e-314,
lum_C33_l = 6.9533488359529381e-310, slope =
0.075450657666172191, aspect = 5.0632796287624782}
sunRadVar = {cbh = 1, cdh = 1, linke = 3, G_norm_extra =
1381.7904736323146, alb = 0.20000000000000001}
#3 0x000000000040488b in main (argc=9, argv=0x7fffffffd638) at main.c:768
singleSlope = 1.2135880960744616e-311
singleAspect = 3.6562339989189768e-319
singleAlbedo = 0.20000000000000001
singleLinke = 3
module = 0x7ffff7bd4f40
parm = {elevin = 0x7ffff7bd4ea0, aspin = 0x613da0, aspect =
0x613e70, slopein = 0x613f40, slope = 0x614010,
linkein = 0x6140e0, lin = 0x6141b0, albedo = 0x614280, longin =
0x6145c0, alb = 0x614350, latin = 0x614420,
lat = 0x6144f0, coefbh = 0x614690, coefdh = 0x614760, incidout =
0x6149d0, beam_rad = 0x614aa0,
insol_time = 0x614b70, diff_rad = 0x614c40, refl_rad = 0x614d10,
glob_rad = 0x614de0, day = 0x614eb0,
---Type <return> to continue, or q <return> to quit---
step = 0x614f80, declin = 0x615050, ltime = 0x615120, dist =
0x6151f0, horizon = 0x614830,
horizonstep = 0x614900, numPartitions = 0x6152c0, civilTime =
0x615390}
flag = {shade = 0x7ffff7bd4e60, saveMemory = 0x615490}
gridGeom = {xp = 6.9531436082559572e-310, yp = 0, xx0 =
6.9533491762080433e-310, yy0 = 0,
xg0 = 6.9533491624931762e-310, yg0 = 6.9533491654678467e-310,
stepx = 10, stepy = 10, deltx = 15000,
delty = 13500, stepxy = 10, sinlat = 6.9533558072840223e-310,
coslat = 6.9533558072852081e-310}
Ticket URL: <http://trac.osgeo.org/grass/ticket/1431>
