[GRASS-dev] [GRASS GIS] #1432: wxGUI GDAL/OGR Importer: changing format doesn't affect list of layers
Reporter: martinl | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: gdal importer | Platform: Unspecified
      Cpu: Unspecified |
Using GDAL/OGR wxGUI importer: when changing format list of layers should
be reloaded. Hopefully fixed in r48007, waiting for backport to relbr64.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1432&gt;
      Cpu: Unspecified |
Comment(by martinl):
To extent this ticket, importer should also allow user to type alternative
extension for format selector.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1432#comment:1&gt;
      Cpu: Unspecified |
Replying to [comment:1 martinl]:
alternative extension for format selector.
try r48008 (devbr6). Candidate for backport to relbr64.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1432#comment:2&gt;
      Cpu: Unspecified |
Replying to [comment:2 martinl]:
include also in for possible r48009
Ticket URL: <http://trac.osgeo.org/grass/ticket/1432#comment:3&gt;
nothing to do with the ticket, but vaguely related:
I notice in trunk that ESRI Shapefile has just been removed as
the default output format. Why is that? It is the most common
choice by far and is a pain to have to type.
thanks,
Hamish
2011/8/31 Hamish <hamish_b@yahoo.com>:
usually you forget to define format when you don't want to write out
Shapefile (it happened thousand times when working with PostGIS). It
will just silently write Shapefile and that's the pain. The module is
not called v.out.shapefile, but v.out.ogr. Well, cosmetic issue
compared to others.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
2011/9/1 Martin Landa <landa.martin@gmail.com>:
compared to others.
similarly, default format (in this case GTiff) should not defined for
r.out.gdal in G7.
Martin
      Cpu: Unspecified |
Replying to [comment:3 martinl]:
done in r48269. Testing highly welcomed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1432#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: gdal importer
  Platform: Unspecified | Cpu: Unspecified
Changes (by martinl):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1432#comment:5&gt;
