#1435: Quotes are stripped from command display
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: unspecified
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
In GRASS GIS Layer Manager's '''Command Console''', if I type a command
with quotes, such as '''v.in.ogr -o dsn="...DSN goes here..." ...''', the
quotes are stripped from the display when the command is repeated back at
me in the output window after I press enter.
This is significant because the positioning of quotes makes a huge
difference in how commands are interpreted.
This is in version 6.4.1 (not available in the dropdown).
