#1438: g.remove cannot remove vector map
Reporter: arencambre | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: unspecified
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
I have a vector map named '''pointdata'''. I can confirm this because if I
run '''v.in.ogr''' against a PostGIS database with '''output''' set to
'''pointdata''', the command's output is:
'''ERROR: Vector map <pointdata> already exists'''
Yet when I run '''g.remove pointdata''', I get:
'''Removing raster <pointdata>
Raster map <pointdata> not found
<pointdata> nothing removed'''
But then you may say, "Hey, moron, that's a vector layer! Use the right
command." OK, I ran '''g.remove vect=pointdata''' and I get:
'''Removing vector <pointdata>
DBMI-DBF driver error:
Unable to open database <cat C:\Users\Aren Cambre\Desktop\DEEM
documents\GRASS\DallasCountyCrashes\Crases2\dbf\> by driver <dbf>
Unable open database <cat C:\Users\Aren Cambre\Desktop\DEEM
Unable to find table <crash> linked to vector map <pointdata>
couldn't be removed
I've attached a copy of the mapset in concern.
This is for GRASS GIS 6.4.1 (that option not available in the
'''Version''' dropdown).
the layer name (raw.TxDOT crash) is not allowed to have a space in it with
GRASS 6. In GRASS 7 the separator becomes a "|" instead of a space so they
are allowed there. GRASS 6 can read dbln files with "|" as the fields
separator, so you might try to edit it by hand to:
#1438: g.remove cannot remove vector map because of space in DB layer name
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.4
Component: Database | Version: 6.4.1
Resolution: | Keywords: dbln, g.remove, layer name
Platform: MSWindows 7 | Cpu: Unspecified
Comment(by neteler):
Replying to [comment:3 hamish]:
> Hi,
> your vector/pointdata/dbln file looks like this:
> 1/raw.TxDOT crash pointdata cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
dbf
> with GRASS 6. In GRASS 7 the separator becomes a "|" instead of a space
> so they are allowed there.
So that looks like "wontfix" for GRASS 6 (since we cannot change the
format)
and "already solved" in GRASS 7?
