#1450: grass 6.4.svn nightly build fails on startup
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
I just downloaded the latest nightly 6.4svn build r48286
the without msys icon doesn't launch grass, the with-msys gives this error
in the terminal after you chose your mapset and click [continue] ..
Welcome to GRASS 6.4.2svn (2011)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4> Traceback (most recent call last):
File "c:/Program Files/GRASS 6.4.SVN/etc/wxpython/wxgui.py", line 65, in
<modu le>
from gui_modules import layertree
File "c:\Program Files\GRASS
6.4.SVN\etc\wxpython\gui_modules\layertree.py", l
ine 44, in <module>
import toolbars
File "c:/osgeo4w/usr/src/grass64_release/dist.i686-pc-
mingw32/etc/wxpython/gui _modules/toolbars.py", line
44, in <module>
mingw32/etc/wxpython/gui _modules/vdigit.py", line
43, in <module>
6.4.SVN\etc\wxpython\gui_modules\wxvdigit.py", li ne
25, in <module>
from wxvdriver import DisplayDriver
6.4.SVN\etc\wxpython\gui_modules\wxvdriver.py", l
ine 28, in <module>
from grass.lib.gis import *
File "c:\Program Files\GRASS 6.4.SVN\etc\python\grass\lib\__init__.py",
line 4 , in <module>
import proj
File "c:\Program Files\GRASS 6.4.SVN\etc\python\grass\lib\proj.py", line
23, i n <module>
_libs["grass_gproj.6.4.2svn"] = load_library("grass_gproj.6.4.2svn")
6.4.SVN\etc\python\grass\lib\ctypes_loader.py", l
ine 55, in load_library
return self.load(path)
ine 221, in load
return _WindowsLibrary(path)
ine 207, in __init__
self.cdll = ctypes.cdll.LoadLibrary(path)
File "C:\Program Files\GRASS 6.4.SVN\Python25\lib\ctypes\__init__.py",
line 43 1, in LoadLibrary
return self._dlltype(name)
line 34 8, in __init__
self._handle = _dlopen(self._name, mode)
WindowsError: [Error 14001] This application has failed to start because
the app lication configuration is incorrect.
Reinstalling the application may fix this p roblem
GRASS 6.4> g.version.exe
GRASS 6.4.2svn48286 (2011)
GRASS 6.4>
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1450>
