[GRASS-dev] [GRASS GIS] #1451: r.li.mps (mean patch size): SIGPIPE at ipc.c:31
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Raster | Version: svn-develbranch6
Keywords: r.li.mps | Platform: Linux
      Cpu: x86-64 |
as reported on the ML, r.li.mps falls over with a SIGPIPE. Running outside
of gdb results in a "double free or corruption (fasttop)" fault.
to reproduce: (North Carolina dataset)
g.region rast=landcover_1m
r.mapcalc "forest.test = if(landcover_1m == 2, 1, null())"
mkdir -p ~/.r.li/history/
cat << EOF > ~/.r.li/history/movwindow7
SAMPLINGFRAME 0|0|1|1
SAMPLEAREA -1|-1|0.0147679324895|0.0133079847909
MOVINGWINDOW
EOF
r.li.mps map=forest.test conf=movwindow7 out=mps.test
Program received signal SIGPIPE, Broken pipe.
gdb session extracts:
(gdb) frame 2
#2 0x00007ffff754edc9 in calculateIndex (file=0x605270 "movwindow7",
f=0x4013a7 <meanPatchSize>, parameters=0x0,
     raster=0x605250 "forest1996.maybe", output=0x605590 "test.out") at
daemon.c:198
198 send(child[j].channel, &m);
(gdb) list
193 j = 0;
194
195
196 while (j < WORKERS && donePid != child[j].pid)
197 j++;
199
200 }
201
202 /*kill childs */
(gdb) frame 1
#1 0x00007ffff7551365 in send (pipe=5, m=0x7fffffffaa80) at ipc.c:31
31 check = write(pipe, m, sizeof(msg));
(gdb) list
26 int send(int pipe, msg * m)
27 {
28 int check;
29
30 /* write on pipe */
32 if (check > 0)
33 return 1;
34 else
35 return 0;
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1451&gt;
      Cpu: x86-64 |
Comment(by hamish):
ps- see #1323 for some automatically detected problems by Cppcheck
  ./raster/r.li/r.li.mps/mps.c:159 [error] - Resource leak: mask_fd
  ./raster/r.li/r.li.mps/mps.c:530 [error] - Resource leak: mask_fd
  ./raster/r.li/r.li.mps/mps.c:900 [error] - Resource leak: mask_fd
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1451#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
r.li.patchdensity has the same trouble, complains about double-free or
corruption.
by setting WORKERS=1 and g.gisenv DEBUG=1, I can see that the main
patch_density() runs twice, the first time the G_free(sup) command runs
ok, the second time it tries to run that it crashes.
a gdb backtrace shows it crashing in the same place as r.li.mps given
above, at `send(child[j].channel, &m)`.
# main r.li man page spearfish example
G65> export WORKERS=1
G65> r.li.patchdensity map=geology conf=testconf16 out=patch.dens --v
D1/1: r.li.daemon pathSetup: [/home/hamish/.r.li/history/testconf16]
D1/1: begin patch_density() index
*** glibc detected *** r.li.patchdensity: double free or corruption
(fasttop): 0x0000000001aacdd0 ***
======= Backtrace: =========
/lib/libc.so.6(+0x71e16)[0x7f1a78f72e16]
/lib/libc.so.6(cfree+0x6c)[0x7f1a78f77b8c]
/home/hamish/src/grass/svn/grass65/dist.x86_64-unknown-linux-
gnu/lib/libgrass_gis.6.5.svn.so(G_free+0x18)[0x7f1a79b247db]
r.li.patchdensity(patch_density+0x75f)[0x401666]
gnu/lib/libgrass_rli.so(worker+0x6f5)[0x7f1a794ead49]
gnu/lib/libgrass_rli.so(calculateIndex+0x35f)[0x7f1a794e7aeb]
r.li.patchdensity(main+0xf1)[0x400f05]
/lib/libc.so.6(__libc_start_main+0xfd)[0x7f1a78f1fc8d]
r.li.patchdensity[0x400d59]
======= Memory map: ========
00400000-00402000 r-xp 00000000 09:01 1998212
gnu/bin/r.li.patchdensity
00601000-00602000 rw-p 00001000 09:01 1998212
01a96000-01ab7000 rw-p 00000000 00:00 0
[heap]
7f1a74000000-7f1a74021000 rw-p 00000000 00:00 0
7f1a74021000-7f1a78000000 ---p 00000000 00:00 0
7f1a78ae7000-7f1a78afd000 r-xp 00000000 09:00 1175043
/lib/libgcc_s.so.1
7f1a78afd000-7f1a78cfc000 ---p 00016000 09:00 1175043
/lib/libgcc_s.so.1
7f1a78cfc000-7f1a78cfd000 rw-p 00015000 09:00 1175043
/lib/libgcc_s.so.1
7f1a78cfd000-7f1a78cff000 r-xp 00000000 09:00 1180574
/lib/libdl-2.11.3.so
7f1a78cff000-7f1a78eff000 ---p 00002000 09:00 1180574
7f1a78eff000-7f1a78f00000 r--p 00002000 09:00 1180574
7f1a78f00000-7f1a78f01000 rw-p 00003000 09:00 1180574
7f1a78f01000-7f1a7905a000 r-xp 00000000 09:00 1179836
/lib/libc-2.11.3.so
7f1a7905a000-7f1a79259000 ---p 00159000 09:00 1179836
/lib/libc-2.11.3.so
7f1a79259000-7f1a7925d000 r--p 00158000 09:00 1179836
/lib/libc-2.11.3.so
7f1a7925d000-7f1a7925e000 rw-p 0015c000 09:00 1179836
/lib/libc-2.11.3.so
7f1a7925e000-7f1a79263000 rw-p 00000000 00:00 0
7f1a79263000-7f1a792e3000 r-xp 00000000 09:00 1180575
/lib/libm-2.11.3.so
7f1a792e3000-7f1a794e3000 ---p 00080000 09:00 1180575
/lib/libm-2.11.3.so
7f1a794e3000-7f1a794e4000 r--p 00080000 09:00 1180575
/lib/libm-2.11.3.so
7f1a794e4000-7f1a794e5000 rw-p 00081000 09:00 1180575
/lib/libm-2.11.3.so
7f1a794e5000-7f1a794ee000 r-xp 00000000 09:01 1988192
gnu/lib/libgrass_rli.6.5.svn.so
7f1a794ee000-7f1a796ee000 ---p 00009000 09:01 1988192
7f1a796ee000-7f1a796ef000 rw-p 00009000 09:01 1988192
7f1a796ef000-7f1a79706000 r-xp 00000000 09:00 1047279
/usr/lib/libz.so.1.2.3.4
7f1a79706000-7f1a79905000 ---p 00017000 09:00 1047279
7f1a79905000-7f1a79906000 rw-p 00016000 09:00 1047279
7f1a79906000-7f1a7990f000 r-xp 00000000 09:01 1988074
gnu/lib/libgrass_datetime.6.5.svn.so
7f1a7990f000-7f1a79b0f000 ---p 00009000 09:01 1988074
7f1a79b0f000-7f1a79b10000 rw-p 00009000 09:01 1988074
7f1a79b10000-7f1a79b76000 r-xp 00000000 09:01 1988086
7f1a79b76000-7f1a79d75000 ---p 00066000 09:01 1988086
7f1a79d75000-7f1a79d78000 rw-p 00065000 09:01 1988086
7f1a79d78000-7f1a79d79000 rw-p 00000000 00:00 0
7f1a79d79000-7f1a79d97000 r-xp 00000000 09:00 1178057
/lib/ld-2.11.3.so
7f1a79f6f000-7f1a79f73000 rw-p 00000000 00:00 0
7f1a79f93000-7f1a79f96000 rw-p 00000000 00:00 0
7f1a79f96000-7f1a79f97000 r--p 0001d000 09:00 1178057
/lib/ld-2.11.3.so
7f1a79f97000-7f1a79f98000 rw-p 0001e000 09:00 1178057
/lib/ld-2.11.3.so
7f1a79f98000-7f1a79f99000 rw-p 00000000 00:00 0
7fff66a9c000-7fff66ab1000 rw-p 00000000 00:00 0
[stack]
7fff66bff000-7fff66c00000 r-xp 00000000 00:00 0
[vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
[vsyscall]
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1451#comment:2&gt;
Priority: normal | Milestone: 6.4.4
Keywords: r.li.mps, r.li.daemon | Platform: Linux
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: r.li.mps => r.li.mps, r.li.daemon
  * milestone: 6.4.2 => 6.4.4
Comment:
see also comment 27 in #2024, same crash in the same place but set off by
r.li.edgedensity. Includes backtrace and valgrind analysis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1451#comment:3&gt;
      Cpu: x86-64 |
Comment(by mmetz):
Replying to [comment:3 hamish]:
by r.li.edgedensity. Includes backtrace and valgrind analysis.
r.li.mps is fixed in trunk r59072. As with the other r.li modules, it
works only reliably if the current region is set to the input raster.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1451#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.li.mps, r.li.daemon
  Platform: Linux | Cpu: x86-64
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Rewrite from trunk backported in r59304.
Closing here, continued in bug #1214.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1451#comment:5&gt;
