[GRASS-dev] [GRASS GIS] #1469: wxgui vector query doesn't work for maps without attribute table
Reporter: marisn | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: All
      Cpu: Unspecified |
Import vector data set without attribute data. Add to layer manager.
Select it. Choose "query" tool in map display. Click on vector object:
   File "/home/maris/soft/grass_trunk/dist.x86_64-unknown-
linux-gnu/etc/gui/wxpython/gui_modules/mapdisp_window.py",
line 1114, in MouseActions
self.OnLeftUp(event)
line 1304, in OnLeftUp
self.parent.QueryVector(self.mouse['begin'][0],
self.mouse['begin'][1])
linux-gnu/etc/gui/wxpython/gui_modules/mapdisp.py", line
1081, in QueryVector
action = mode)
linux-gnu/etc/gui/wxpython/gui_modules/dbm_dialogs.py", line
363, in UpdateDialog
query[1])
linux-gnu/etc/gui/wxpython/gui_modules/dbm_base.py", line
104, in SelectByPoint
table = data[0]['Table']
KeyError
'Table'
Expected results: query tool should report geometry properties, object id
etc. and not fail with cryptic error.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469&gt;
Reporter: marisn | Owner: martinl
     Type: defect | Status: assigned
Priority: normal | Milestone: 6.4.2
      Cpu: Unspecified |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
  * milestone: => 6.4.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:1&gt;
      Cpu: Unspecified |
Comment(by martinl):
Should be already fixed, try more recent version from SVN.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: All | Cpu: Unspecified
  * status: assigned => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:3&gt;
      Type: enhancement | Status: reopened
Resolution: | Keywords:
Changes (by marisn):
  * status: closed => reopened
  * type: defect => enhancement
  * resolution: fixed =>
Comment:
The crash part is fixed, still it doesn't work as expected, as it reports
"nothing found" when I click inside areas.
Compare output on same feature of gis.m from 6.4 and wxgui from 7
(r49125):
gis.m
East: 587289.62070973
North: 6379709.31901164
Map: rm_me
Mapset: malasveidojumi
Type: Area
Sq Meters: 3144180724.195
Hectares: 314418.072
Acres: 776943.977
Sq Miles: 1213.9750
Layer: 1
Category: 2
wxgui
Nothing found.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:4&gt;
Comment(by cmbarton):
This is still broken in 6.4.3. It used to work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:5&gt;
Comment(by annakrat):
This should be fixed for GRASS 7 by this r52832. Please could you test it
with your data so that I can backport it before release?
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:6&gt;
  Priority: normal | Milestone: 6.4.3
  * milestone: 6.4.2 => 6.4.3
Comment:
Tested with GRASS 7 and now it works. Please, backport this to 6.4.3.
Related discussion on how it could work better is in #1703
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:7&gt;
      Type: enhancement | Status: closed
Changes (by annakrat):
  * status: reopened => closed
Comment:
Backported in r52853, r52855 so I'm closing this ticket.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1469#comment:8&gt;
