#1471: Interactive geometry selection and export tool for wxgui
Reporter: marisn | Owner: grass-dev@…
Priority: normal | Milestone:
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Currently there is no easy way how to select single or multiple vector
objects in the map display for later usage or export.
Vector selection tool should provide following functionality:
* ability to select vector feature type for selection (important for area
vs centroid/boundary)
* ability to get geometry ID list as a result
* ability to get CAT list as a result
* ability to save result as a new GRASS vector data map
* ability to visually identify list item on the screen
* ability to remove items from list
