#1479: error running v.generalize under Windows/Osgeo4w
Reporter: lutra | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Vector | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: Unspecified |
I see the same "pattern" as in #1477
Using the Wxpython interface it works.
Using the QGIS/GRASS interface it doesn't, but using the QGIS/GRASS
interface under Linux works fine.
The command produced by the QGIS/GRASS interface is
v.generalize input=freguesias@mapset_agueda type=area layer=1 -c
type=boundary method=douglas threshold=200 look_ahead=7 reduction=50
slide=0.5 angle_thresh=3 degree_thresh=0 closeness_thresh=0
betweeness_thresh=0 alpha=1.0 beta=1.0 ite
rations=1 layer=1 output=gene_qgisgrass
but the same command under Linux works fine
v.generalize input=provincias@mapset_agueda type=area layer=1 -c
betweeness_thresh=0 alpha=1.0 beta=1.0 iterations=1 layer=1
output=gene_qgisgrasslinux
while removing the "layer=1" parameters works also under Window/QGIS/GRASS
CLI
v.generalize input=freguesias@mapset_agueda type=area -c type=boundary
method=douglas threshold=200 look_ahead=7 reduction=50 slide=0.5
angle_thresh=3 degree_thresh=0 closeness_thresh=0 betweeness_thresh=0
rations=1 output=gene_qgisgrass
Ticket URL: <http://trac.osgeo.org/grass/ticket/1479>
