[GRASS-dev] [GRASS GIS] #1482: Wish - update to v.in.osm2
Reporter: rchirgwin | Owner: grass-dev@…
     Type: task | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Per this note from Hamish on the Grass-GIS list:
since january osm devs have built a new work-alike of
xapi written in java which is not quite as complete, but can
be supported and distributed by the available resources.
for the osgeo live dvd I have documented the almost-the-same-
but-not-quite new java Xapi method, please file a wish and I'll
fix v.in.osm2
Ticket URL: <http://trac.osgeo.org/grass/ticket/1482&gt;
Component: Vector | Version: unspecified
Keywords: v.in.osm2 | Platform: Unspecified
      Cpu: Unspecified |
Changes (by martinl):
  * keywords: => v.in.osm2
  * component: Default => Vector
  * milestone: => 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1482#comment:1&gt;
Reporter: rchirgwin | Owner: hamish
     Type: task | Status: assigned
Priority: normal | Milestone: 6.4.2
      Cpu: Unspecified |
Changes (by hamish):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => hamish
  * status: new => assigned
  * milestone: 7.0.0 => 6.4.2
Comment:
(grass 6 addons script)
for current method see
https://trac.osgeo.org/osgeo/browser/livedvd/gisvm/trunk/bin/install_osm.sh#L154
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1482#comment:2&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: v.in.osm2
  Platform: Unspecified | Cpu: Unspecified
  * status: assigned => closed
  * resolution: => fixed
Comment:
fixed in r49063.
currently the main Xapi server is down, but there are a couple other
backup servers available from the OSM Xapi wiki page.
  http://wiki.openstreetmap.org/wiki/Xapi#Java
e.g. extract private roads in Spearfish County using a backup server
  g.region -d
  v.in.osm out=test_osm_ways_private feature=ways \
    query="way[access=private]" \
    server="http://open.mapquestapi.com/xapi/api/0.6&quot;
(this addon requires GRASS 6.4.2rc1 or newer)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1482#comment:3&gt;
