#1487: r.stream.order returns error while create vector stream. error: "unable to
... driver (pg)"
Reporter: pkscwc | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Default | Version: unspecified
Keywords: r.stream.order vector table postgres database | Platform: Unspecified
Cpu: Unspecified |
I have consistently reproduced the error reported by r.stream.order.
The add-on module creates the vector stream but the creation of
corresponding table in postgres database fails with error "unable to ..
driver(pg)". Although database is connected properly. New vectors are
being created by other modules along with the table in postgres.
