[GRASS-dev] [GRASS GIS] #1491: python libs shouldn't parse freeform text fields with parse_key_val()
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Component: Python | Version: svn-trunk
Keywords: parsing | Platform: All
      Cpu: All |
raster.py and vector.py use core.py's parse_key_val() to evaluate the
results of r.info and v.info, and report the result of `kv[1]` using `=`
as the field separator.
r.info's title, vdatum, and units results, and most of v.info's extended
metadata results can contain free-from text, which can contain `=` chars.
And so text containing that will get cut off and only give the result up
to the first `=`.
vector_info_topo(v.info -t) looks safe to use it.
db.py contains one too, using `:` as the fs, it is easy to imagine this
failing if the database: string is on MS Windows and contains `C:\`, only
the initial drive letter would get through.
raster3d.py's one should be ok, I don't spot any free-form text options in
`r3.info`.
`g.region -g` in core.py should be safe too.
`g.findfile` in core.py won't be safe if the file= path contains a `=`. I
suspect that's safe on MS Windows but not in UNIX?
thanks,
Hamish
ps- r.info and v.info's -g flags restored to their original "show region"
meanings in trunk. maybe `r.info -s` (show res) should get merged into -g,
a bunch of the others could not be eval'd and had to be moved back out.
after doing that it became obvious that leaving the rest was inconsistent
and breaking the meaning of what -g has historically been for, so backed
out as well.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1491&gt;
      Cpu: All |
Comment(by huhabla):
A solution would be that parse_key_val() accepts only the first "=" to
create the key value pair. In case of free form text, the reporting module
should put the info in double quotes, escaping all other double quotes
located in the message content.
So parse_key_val() is able to detect any content with quotes and new lines
as values.
Using several different and between the modules inconsistent flags to
print content in shell style is IMHO not a better solution.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1491#comment:1&gt;
      Cpu: All |
Comment(by glynn):
Replying to [ticket:1491 hamish]:
to the first `=`.
parse_key_val() only splits at the first separator:
         kv = line.split(sep, 1)
This results in a two-element tuple, with the first element containing
everything before the first separator, and the second element containing
everything after, even if it contains the separator character.
Unless there are specific cases which either actually don't work or which
are uncertain based upon the actual behaviour of parse_key_val(), this
ticket should be closed as "invalid".
Ticket URL: <https://trac.osgeo.org/grass/ticket/1491#comment:2&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: parsing
  Platform: All | Cpu: All
Changes (by hamish):
  * status: new => closed
  * resolution: => invalid
Comment:
Replying to [comment:2 glynn]:
which
ah, that's good. I missed the ,1 and was assuming it was designed to work
like G_tokenize(), with as many array items as number of seps+1.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1491#comment:3&gt;
