[GRASS-dev] [GRASS GIS] #1494: v.in.ogr key flag does not change category values and you loose connection between features and attributes (was: wish: v.in.ogr add possibility to use existing attribute column as category value, including with -t option
  Reporter: mlennert | Owner: grass-dev@…
      Type: defect | Status: reopened
  Priority: major | Milestone: 7.0.5
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.in.ogr
Changes (by mlennert):
* status: closed => reopened
* priority: normal => major
* type: enhancement => defect
* resolution: worksforme =>
Comment:
Replying to [comment:3 martinl]:
> `v.in.ogr` in GRASS 7 has `key` parameter which allows you to define key
column,
Yes, but apparently it doesn't work:
g.copy vect=boundary_county,bc
v.db.addcol bc col="newcat int"
v.db.addcolumn bc col="newcat int"
v.db.update bc col=newcat qcol=cat+1000
v.out.ogr bc out=bc
v.in.ogr bc/bc.shp out=bc_test key=newcat
v.db.connect -p bc_test
v.db.univar bc_test col=newcat
v.category bc_test op=report
You will see that the db connection is correctly defined with the 'newcat'
column as the key, but the features' category values are still
automatically generated from 1. You thus loose the connection between
features and attributes !
Redefining this as a bug and reopening.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1494#comment:4&gt;
