#1497: OSGeo4W-GRASS: r.shaded.relief starts Windows XP mode (VM)
Reporter: pietror3 | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
Using OSGeo4W-GRASS 7.svn on Windows7-64bit, when starting
r.shaded.relief from the wxGUI menu, it starts indeed the
Windows XP mode (virtual machine) and does not continue.
Trying instead on command line, I get this error:
GRASS 7.0.svn> r.shaded.relief.py
File
"C:\OSGeo4W\apps\grass\grass-7.0.svn/etc/gui/wxpython/gui_modules/menufor
m.py", line 2223, in <module>
task = gtask.grassTask(cmd[0], blackList = _blackList)
File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
mingw32/etc/python/grass/scr
ipt/task.py", line 67, in __init__
File "C:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py", line 964,
in XML
return parser.close()
File "C:\OSGeo4W\apps\Python25\lib\xml\etree\ElementTree.py", line 1254,
in cl
ose
self._parser.Parse("", 1) # end of data
xml.parsers.expat.ExpatError: no element found: line 1, column 0
GRASS 7.0.svn>
