[GRASS-dev] [GRASS GIS] #1498: patch proposal: new option for v.category to copy category values from one layer to another
layer to another
Reporter: mlennert | Owner: grass-dev@…
Component: Vector | Version: unspecified
Keywords: v.category | Platform: Unspecified
      Cpu: Unspecified |
In the attached patch againts trunk I propose an implementation of a
feature in v.category requested regularly in the mailing lists: copying
category values from one layer to another.
I don't think that it is a very invasive addition, but someone should
probably check before we apply this to trunk. It could possibly also go
into 6.5 as it doesn't break backwards compatibility.
I used the word 'transfer' for this option as the way the parser works I
needed a word with a different first letter than the others, and 'c'(opy)
was already taken by 'c'(hlayer).
On thing I did not put in is a way how to work with type=area. I just exit
with a message proposing to use type=centroid to copy category values for
areas. If someone wants to implement the same with type=area working,
please do so.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1498&gt;
layer to another
      Cpu: Unspecified |
Comment(by mmetz):
Very useful addition, the transfer option!
The attached second patch copies not only the first cat encountered but
all cats of the first layer to the second layer. Type = centroid is now
automatically activated if type = area and not type=area,centroid.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1498#comment:1&gt;
layer to another
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:1 mmetz]:
Thanks, Markus, for looking into this. Can we apply to trunk ? And what
about 6.x ?
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1498#comment:2&gt;
layer to another
      Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:2 mlennert]:
but all cats of the first layer to the second layer. Type = centroid is
now automatically activated if type = area and not type=area,centroid.
about 6.x ?
I have added the new feature of copying categories in r49413, but with
further modifications because the category/layer design of GRASS vectors
is quite flexible and thus probably a bit complicated:
  * A warning is printed if categories already exist in the target layer
(where categories are copied to). This could lead to all sorts of
complications. I was contemplating a fatal error, but then I decided to
follow GRASS policy: allow a lot, warn if it may be dangerous.
  * There is a new hidden feature for option=transfer, if only one layer
number is given for the layer option, the module will find the next free
layer number and copy categories to that new layer. No danger of confusion
with already existing categories in that layer since it's new. This
feature is hidden in the sense that it is documented somewhat further down
the manual.
Since I was on it, I changed the behaviour of option=chlayer a bit: the
layer number of categories is changed (as before) if the current category
number does not exist for the target layer, otherwise it is only deleted
from the source layer (new). This avoids duplicate category entries of a
given geometry object in the target layer.
All changes are tested and should be backported to 6.x since they maintain
backwards compatibility and fix an obscure but potentially disastrous bug.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1498#comment:3&gt;
