GDAL
1
#1499: v.surf.rst in trunk doesn't create write the output map
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.surf.rst | Platform: Linux
Cpu: x86-64 |
I can't get v.surf.rst in trunk to create any output.
spearfish:
g.region -d
g.copy vect=archsites,arch_cp
v.build arch_cp
v.surf.rst in=arch_cp zcol=cat elev=test.rst
Processing segments...
100%
WARNING: Raster map <test.rst> not found
ERROR: Unable to write raster maps - try to increase resolution
no matter what I try, same thing.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1499>
GDAL
2
#1499: v.surf.rst in trunk doesn't write the output map
Cpu: x86-64 |
Ticket URL: <https://trac.osgeo.org/grass/ticket/1499#comment:1>
GDAL
3
Cpu: x86-64 |
Comment(by mmetz):
Fixed in r49417.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/1499#comment:2>
GDAL
4
Type: defect | Status: closed
Resolution: fixed | Keywords: v.surf.rst
Platform: Linux | Cpu: x86-64
Changes (by hamish):
* status: new => closed
* resolution: => fixed
Comment:
thanks.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1499#comment:3>
