GDAL
December 7, 2011, 3:07am
1
#1503: parser error with db.select
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Component: LibGIS | Version: svn-trunk
Keywords: parser, db.select | Platform: Linux
Cpu: x86-64 |
NC2008 dataset in trunk:
GRASS7> db.select precip_30ynormals_g7 \
sql="select annual from precip_30ynormals_g7 where cat=2"
Description:
Selects data from attribute table (performs SQL query statement(s)).
Keywords:
database, attribute table, SQL
Usage:
db.select [-cdvt] [sql=string] [input=name] [table=name]
[database=name] [driver=name] [fs=character] [vs=character]
[nv=string] [output=name] [--overwrite] [--verbose] [--quiet]
ERROR: Option <sql> does not accept multiple answers
I guess it doesn't like the 'where cat=2'
`v.db.select where="cat=2"` seems ok though.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
December 7, 2011, 3:50am
2
Priority: critical | Milestone: 6.5.0
Cpu: x86-64 |
Changes (by hamish):
* priority: normal => critical
* milestone: 7.0.0 => 6.5.0
Comment:
this also happens in recent 6.5svn, but it seems to work ok in 6.4svn.
see also #1444 "g.parser does not filter for duplicate output map
statements"
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503#comment:1> ;
GDAL
December 7, 2011, 7:39am
3
Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1503 hamish]:
No, it doesn't like you specifying the sql= option twice. Note that the
default option is sql=, not table=.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503#comment:2> ;
GDAL
December 7, 2011, 7:54am
4
Component: LibGIS | Version: svn-develbranch6
Cpu: x86-64 |
* version: svn-trunk => svn-develbranch6
Comment:
d'oh! the options got reordered..
I am not sure if this ticket should be closed as invalid, or if re-
ordering the primary option in 6.x should be considered a break in
backwards compatibility, although one that only bites those taking command
line shortcuts. If it is, devbr6 should be put back to its old way before
forgetting about this ticket.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503#comment:3> ;
GDAL
5
Priority: minor | Milestone: 6.5.0
Cpu: x86-64 |
* priority: critical => minor
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503#comment:4> ;
GDAL
May 2, 2013, 8:51am
6
Type: defect | Status: closed
Resolution: fixed | Keywords: parser, db.select
Platform: Linux | Cpu: x86-64
* status: new => closed
* resolution: => fixed
Comment:
devbr6 reordered back to the old way in r56074.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1503#comment:5> ;
