#1510: Querying external PostGIS-layer with multiple geometries crashes wxpython-
GUI
Reporter: grasslandtom | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 6.4.2 RCs
Keywords: wxpython, PostGIS, v.external | Platform: Unspecified
Cpu: Unspecified |
steps to reproduce:
_ import a PostGIS-layer with multiple geometries; something like
v.external dsn='db=mydb' out=vector layer='v_eca_data(coords_gk_em38)'
_ adding the vector-layer to the map in the GUI raises on the console:
ERROR 1: FEHLER: aktuelle Transaktion wurde abgebrochen, Befehle werden
bis zum Ende der Transaktion ignoriert
DBMI-OGR driver error:
Cannot select:
select * from v_eca_data(coords_gk_em38)
GRASS_INFO_WARNING(10090,1): Unable to open select cursor: 'select * from
GRASS_INFO_END(10090,1)
GRASS_INFO_ERROR(10093,1): Unable to describe table
<v_eca_data(coords_gk_em38)>
GRASS_INFO_END(10093,1)
_ Clicking on a feature of the layer with the query tool on the map
crashes the GUI and raises the same error
It seems to me that the problem is the wrong table name in the query
which should be
Ticket URL: <http://trac.osgeo.org/grass/ticket/1510>
