[GRASS-dev] [GRASS GIS] #1522: dbm_base.py fails with multilayer maps
Reporter: artegion | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: All
      Cpu: All |
map 'test' has two layers
Layer=1 Category=20 Table=net_table
Layer=2 Category=8 Table=links
   File "c:/osgeo4w/usr/src/grass-6.4.2RC2/dist.i686-pc-
mingw32/etc/wxpython/gui_modules/mapdisp_window.py", line
1017, in MouseActions
1207, in OnLeftUp
mingw32/etc/wxpython/gui_modules/mapdisp.py", line 1382, in
QueryVector
mingw32/etc/wxpython/gui_modules/dbm_dialogs.py", line 102,
in __init__
mingw32/etc/wxpython/gui_modules/dbm_dialogs.py", line 360,
in UpdateDialog
   File
"C:\Programmi\Grass\etc\wxpython\gui_modules\dbm_base.py",
line 109, in SelectByPoint
if self.tables[table][key]['ctype'] != types.StringType:
KeyError
'STATUS'
v.what works fine
>> ret = grass.read_command('v.what',
                        quiet = True,
                        flags = 'ag',
                        map = 'test',
                        east_north = '60.0,70.0',
                        distance = '1.0')
>> ret
East=60
North=70
Map=test
Mapset=piacenza
Type=Line
Id=20
Length=20.000000
Layer=1
Category=20
Driver=sqlite
Database=d:\gis_db\gauss-boaga\test_sqlite.db
Table=net_table
Key_column=cat
cat=20
net=
Layer=2
Category=8
Driver=sqlite
Table=links
Key_column=cat
cat=8
ID=12
LTYPE=1
NODE1=12
NODE2=13
LENGTH=5280
DIAMETER=10
ROUGHNESS=100
MLOSS=0
STATUS=Open
PARAMETERS=
TYPE=
SETTINGS=
TAG=ID12
but grass.vector_what puts Layer 2 attributes into Layer 1
>>data = grass.vector_what(map = 'test',coord = (60.0, 70.0), distance =
1.0)
>>data
[{'Category': 20,
'Map': 'test',
'Layer': 1,
'Key_column': 'cat',
'Database': 'd:\\gis_db\\gauss-boaga\\test_sqlite.db',
'Mapset': 'piacenza',
'Driver': 'sqlite',
'Length': '20.000000',
'Attributes': {'STATUS': 'Open',
                'LTYPE': '1',
                'PARAMETERS': '',
                'DIAMETER': '10',
                'SETTINGS': '',
                'MLOSS': '0',
                'cat': '8',
                'LENGTH': '5280',
                'TAG': 'ID12',
                'NODE1': '12',
                'NODE2': '13',
                'TYPE': '',
                'ID': '12',
                'ROUGHNESS': '100'},
'Table': 'net_table',
'Type': 'Line',
'Id': 20}]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1522&gt;
      Cpu: All |
Comment(by artegion):
but from Digitize "Diplay/update attributes" button (wxPython) it
works......
Ticket URL: <http://trac.osgeo.org/grass/ticket/1522#comment:1&gt;
      Cpu: All |
Old description:
1207, in OnLeftUp
QueryVector
in __init__
in UpdateDialog
  File
KeyError
'STATUS'
v.what works fine
                       quiet = True,
                       flags = 'ag',
                       map = 'test',
                       distance = '1.0')
>> ret
East=60
North=70
Map=test
Mapset=piacenza
Type=Line
Id=20
Length=20.000000
Layer=1
Category=20
Driver=sqlite
Table=net_table
Key_column=cat
cat=20
net=
Layer=2
Category=8
Driver=sqlite
Table=links
Key_column=cat
cat=8
ID=12
LTYPE=1
NODE1=12
NODE2=13
LENGTH=5280
DIAMETER=10
ROUGHNESS=100
MLOSS=0
STATUS=Open
PARAMETERS=
TYPE=
SETTINGS=
TAG=ID12
1.0)
>>data
[{'Category': 20,
'Map': 'test',
'Layer': 1,
'Driver': 'sqlite',
               'LTYPE': '1',
               'PARAMETERS': '',
               'DIAMETER': '10',
               'SETTINGS': '',
               'MLOSS': '0',
               'cat': '8',
               'LENGTH': '5280',
               'TAG': 'ID12',
               'NODE1': '12',
               'NODE2': '13',
               'TYPE': '',
               'ID': '12',
'Type': 'Line',
'Id': 20}]
New description:
1207, in OnLeftUp
QueryVector
in __init__
in UpdateDialog
   File
KeyError
'STATUS'
v.what works fine
                        quiet = True,
                        flags = 'ag',
                        map = 'test',
                        distance = '1.0')
>> ret
East=60
North=70
Map=test
Mapset=piacenza
Type=Line
Id=20
Length=20.000000
Layer=1
Category=20
Driver=sqlite
Table=net_table
Key_column=cat
cat=20
net=
Layer=2
Category=8
Driver=sqlite
Table=links
Key_column=cat
cat=8
ID=12
LTYPE=1
NODE1=12
NODE2=13
LENGTH=5280
DIAMETER=10
ROUGHNESS=100
MLOSS=0
STATUS=Open
PARAMETERS=
TYPE=
SETTINGS=
TAG=ID12
1.0)
>>data
[{'Category': 20,
'Map': 'test',
'Layer': 1,
'Driver': 'sqlite',
                'LTYPE': '1',
                'PARAMETERS': '',
                'DIAMETER': '10',
                'SETTINGS': '',
                'MLOSS': '0',
                'cat': '8',
                'LENGTH': '5280',
                'TAG': 'ID12',
                'NODE1': '12',
                'NODE2': '13',
                'TYPE': '',
                'ID': '12',
'Type': 'Line',
'Id': 20}]
Comment(by hamish):
verbatim formatting applied to ticket description.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1522#comment:2&gt;
Keywords: vector_what | Platform: All
      Cpu: All |
Changes (by hamish):
  * keywords: => vector_what
Ticket URL: <https://trac.osgeo.org/grass/ticket/1522#comment:3&gt;
      Cpu: All |
Comment(by wenzeslaus):
The vector_what function (file vector.py) should by fixed in GRASS 7 in
r52824.
vector_what tested with some handmade maps with multiple layers (with and
without dblink). Please, confirm.
This blocked (or blocks) #1606 (part of #1606 is duplicate of this
ticked).
(vector_what is used only in the GUI so r52824 should not break anything.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1522#comment:4&gt;
      Cpu: All |
Comment(by annakrat):
Another related change: r52832. Please test it so that it can be
backported before release.
Thanks, Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1522#comment:5&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: vector_what
  Platform: All | Cpu: All
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
It seems to work, related ticket #1606 was closed as fixed. Backported in
r52853, r52855.
Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/1522#comment:6&gt;
