#1523: v.select segfaults with atype and btype area
Reporter: pertusus | Owner: grass-dev@…
Type: defect | Status: new
Component: Vector | Version: svn-trunk
Keywords: | Platform: Linux
Cpu: x86-64 |
If I do
v.mkgrid map=continent_whole_grid grid=2,2
v.mkgrid map=other_grid grid=4,4
v.select ainput=other_grid atype=area binput=continent_whole_grid
btype=area output=result operator=overlap
I get a segfault. If one of atype or btype is not area, no segfault.
Here is the backtrace
(gdb) run
Starting program: /usr/local/grass-7.0.svn/bin/v.select ainput=other_grid
atype=area binput=continent_whole_grid btype=area output=result
operator=overlap
[Thread debugging using libthread_db enabled]
Processing areas...
18%
Program received signal SIGSEGV, Segmentation fault.
0x000000000040393f in select_lines (aIn=0x7fffffffcad0, atype=16,
afield=1,
bIn=<value optimized out>, btype=64, bfield=1, cat_flag=0, operator=8,
relate=0x0, ALines=0x6aa1a0) at select.c:294
294 if (line_overlap_area(aIn, aline,
(gdb) bt
#0 0x000000000040393f in select_lines (aIn=0x7fffffffcad0, atype=16,
afield=1, bIn=<value optimized out>, btype=64, bfield=1, cat_flag=0,
operator=8, relate=0x0, ALines=0x6aa1a0) at select.c:294
#1 0x0000000000402f0e in main (argc=<value optimized out>,
argv=<value optimized out>) at main.c:115
I attach a tar that can be used to reproduce.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1523>
