[GRASS-dev] [GRASS GIS] #1525: r.mask cannot use float maps
Reporter: pertusus | Owner: grass-dev@…
     Type: defect | Status: new
Component: Raster | Version: svn-trunk
Keywords: | Platform: Linux
      Cpu: x86-64 |
In the r.mask documentation it is said
The mask is read as an integer map. If MASK is actually a
floating-point map, the values will be converted to integers using the
map's quantisation rules (this defaults to round-to-nearest, but can
be changed with r.quant).
But if trying to do a mask with a float raster map, there is an error
message:
echo "0|0|1" | r.in.xyz input=- output=seed
r.mask input=seed
ERROR: Raster map seed must be integer for maskcats parameter
Usint r.quant do not change anything (poking in the dark here, I don't
really understand why r.quant do not need an output map).
r.quant -t seed
r.mask input=seed
A tarball is attached to reproduce the issue.
I had a look at r.mask and r.mask for 6.4.1, besides being a python
script, the difference seems to be that in the svn version there is a test
that the map is indeed a CELL map, which fails and give the error message,
while there was no such test in the shell script. The code is along
       if grass.raster_info(input)['datatype'] != "CELL":
             grass.fatal(_("Raster map %s must be integer for maskcats
parameter") % input)
I have tried without that check and things seems to work. I also attach a
trivial patch that comment that code out. Maybe r.reclass does the magic
float to integer quantification stuff? If it is the case, a comment in
the code, like
# r.reclass takes care of float to integer translation
could be handy.
Maybe the problem is in the doc and really only integer raster map with
type CELL may be used, but then the doc has to be changed and it would be
nice to have a direction, the reference to r.quant not being very useful,
in my opinion.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525&gt;
      Cpu: x86-64 |
Comment(by pertusus):
In fact, the patch I propose leads to other issues down the line. I have
found that r.mapcalc with a mask done with a FCELL raster type fails
strangely later (I have a reproducer for that, in case it is not normal).
So forget about my patch.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:1&gt;
Priority: minor | Milestone: 7.0.0
      Cpu: x86-64 |
Changes (by pertusus):
  * priority: normal => minor
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:2&gt;
      Cpu: x86-64 |
Well, seems that the issue with r.mapcalc also happens with CELL raster
maps, and is very hard to reproduce... So my patch may still be
relevant...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:3&gt;
      Cpu: x86-64 |
Replying to [comment:3 pertusus]:
relevant...
Sorry, this is wrong, the issue only happens with FCELL raster maps as
r.mask...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:4&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1525 pertusus]:
The test was added (incorrectly) in r46379. The CELL requirement should
only apply if the maskcats= option was given. Fixed in r49997.
> Maybe r.reclass does the magic float to integer quantification stuff?
The conversion is performed when the mask is used, not when it is set. It
isn't necessary to use r.mask to create a mask; if a map named MASK exists
in the current mapset, it is automatically used as a mask. The code which
reads raster maps always reads the mask as CELL. The conversion from the
stored type to the requested type (using quantisation rules in the case of
FP->integer conversions) is built into libraster (libgis in versions
before 7.0).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:5&gt;
      Cpu: x86-64 |
It does not solve my issue. I have printed the options, and indeed
maskcats is not null, but *:
if __name__ == "__main__":
     options, flags = grass.parser()
     print options
r.mask input=seed
{'input': 'seed', 'maskcats': '*'}
ERREUR :Raster map seed must be integer for maskcats parameter
This is certainly because of the * below:
#%option
#% key: maskcats
#% type: string
#% description: Category values to use for mask (format: 1 2 3 thru 7 *)
#% answer: *
#% guisection: Create
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:6&gt;
      Cpu: x86-64 |
Replying to [comment:6 pertusus]:
> print options
Correctly formatted:
r.mask input=seed
#%option
#% key: maskcats
#% type: string
#% answer: *
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:7&gt;
      Cpu: x86-64 |
Comment(by glynn):
Oops; try r50019.
AFAICT, 6.x will have the same issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:8&gt;
Priority: minor | Milestone: 6.4.2
      Cpu: x86-64 |
Changes (by neteler):
  * milestone: 7.0.0 => 6.4.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/1525#comment:9&gt;
Priority: minor | Milestone: 6.4.3
Keywords: r.mask, r.reclass | Platform: Linux
      Cpu: x86-64 |
Changes (by hamish):
  * keywords: => r.mask, r.reclass
  * milestone: 6.4.2 => 6.4.3
Comment:
fix backported to devbr6 and relbr64 in r56123,4.
re. the error msg itself, r.reclass doesn't actually mind FP values and
maps as input, that's where the quant rules come into effect.
there is some quant/rounding strangeness going on in r.reclass though:
# spearfish + 6.5svn
G65> g.region -d
G65> r.info -t fields
datatype=CELL
G65> r.mapcalc "seed = float(fields) + 0.55"
G65> r.info -r seed
min=1.55
max=63.55
G65> echo "30.45 thru 40.45 = 1" | r.reclass in=seed out=MASK
30.950000 rounded up to 30
40.950000 rounded up to 40
[Raster MASK present]
? "30.95 rounded up to 30", ... ?
(see scan_value() in r.reclass/parse.c)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1525#comment:10&gt;
