GDAL
December 29, 2011, 5:21pm
1
#1526: "Diplay/update attributes" can freeze GUI
Reporter: artegion | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: MSWindows XP
Cpu: x86-64 |
Digitize "Diplay/update attributes" button (wxPython)
if value type is incorrect (example 'a' in [integer] field ) pressing
Submit button freezes wxPython GUI
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
December 31, 2011, 6:14pm
2
Reporter: artegion | Owner: martinl
Priority: blocker | Milestone: 6.4.3
Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
* owner: grass-dev@… => martinl
* milestone: 6.4.2 => 6.4.3
Comment:
Could you try GRASS 6.5 from (1) - this bug has been probably fixed in
r50007?
[1] http://wingrass.fsv.cvut.cz/grass65/
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:1> ;
GDAL
December 31, 2011, 6:17pm
3
Cpu: x86-64 |
* milestone: 6.4.3 => 6.4.2
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:2> ;
GDAL
December 31, 2011, 6:52pm
4
Cpu: x86-64 |
Comment(by martinl):
It's freezing on
[source:grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gcmd.py#L617
gcmd] (`RunCommand` called from
[source:grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm_dialogs.py#L298
dbm_dialogs])
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:3> ;
GDAL
January 3, 2012, 8:46am
5
Cpu: x86-64 |
Comment(by artegion):
Yes, with 6.5 it works.
(defect with multiple layer ( Ticket #1522 ) remains but it is another
thread...)
Replying to [comment:1 martinl]:
r50007?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:4> ;
GDAL
January 3, 2012, 1:08pm
6
Cpu: x86-64 |
Replying to [comment:4 artegion]:
it's just the coincidence, in G65 simply command which doesn't terminate
is not called. The SQL statement is checked first and then the command
(`db.execute sql=`) is launched. The problem is that the process launched
doesn't terminate in this case.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:5> ;
GDAL
January 3, 2012, 2:06pm
7
Cpu: x86-64 |
Replying to [comment:5 martinl]:
probably not related to wxGUI at all, hopefully fixed in r50051. Can you
confirm it?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:6> ;
GDAL
January 4, 2012, 11:31am
8
Type: defect | Status: closed
Resolution: fixed | Keywords:
Platform: MSWindows XP | Cpu: x86-64
* status: new => closed
* resolution: => fixed
Comment:
confirm it?
tested with (1), seems to work. Closing this ticket, feel free to re-open
if needed.
(1)
http://wingrass.fsv.cvut.cz/grass64/WinGRASS-6.4.SVN-r50051-1-Setup.exe
Ticket URL: <http://trac.osgeo.org/grass/ticket/1526#comment:7> ;
