[GRASS-dev] [GRASS GIS] #1538: wxGUI: Common raster formats importer python error for single file
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: Linux
      Cpu: x86-64 |
When importing with File -> Import -> Common raster formats
-> File (directory works fine) ->
/home/neteler/data/satellite/landsat_etna/srtm_etna_90m_UTM33.tif
I get this error
   File "/usr/lib64/python2.7/site-
packages/wx-2.8-gtk2-unicode/wx/lib/filebrowsebutton.py",
line 140, in OnChanged
self.changeCallback(evt)
   File "/home/neteler/grass64/dist.x86_64-unknown-linux-
gnu/etc/wxpython/gui_modules/gselect.py", line 1439, in
OnSetDsn
self._reloadLayers()
gnu/etc/wxpython/gui_modules/gselect.py", line 1457, in
_reloadLayers
grassName = utils.GetValidLayerName(baseName.split('.',
-1)[0])
gnu/etc/wxpython/gui_modules/utils.py", line 188, in
GetValidLayerName
if not (retName[0] >= 'A' and retName[0] <= 'Z') and \
IndexError
string index out of range
(Mon Jan 16 15:41:44 2012)
r.in.gdal
input=/home/neteler/data/satellite/landsat_etna/srtm_etna_90m_UTM33.tif
output=srtm_etna_90m_UTM33
Projection of input dataset and current location appear to match
r.in.gdal complete. Raster map <srtm_etna_90m_UTM33> created.
(Mon Jan 16 15:41:45 2012) Command finished (0 sec)
The dialog crashes but the map is imported.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1538&gt;
      Cpu: x86-64 |
Changes (by martinl):
* cc: martinl (added)
Comment:
Testing 6.4.2svn I am unable to reproduce this error.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1538#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Linux | Cpu: x86-64
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Works in current 6.4.svn version again. Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1538#comment:2&gt;
