#1539: bug in v.net.components
Reporter: gojira | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: Vector | Version: unspecified
Keywords: net | Platform: Linux
Cpu: x86-32 |
the command v.net.components does not work properly from the version 6.5.
I tried also the version 7.0 of grass but only with actual stable version
6.4 I obtained the right result with lines that goes from one multi-
junction node to another.
Thank you very much.
Cpu: x86-32 |
Comment(by mmetz):
Replying to [ticket:1539 gojira]:
6.5. I tried also the version 7.0 of grass but only with actual stable
version 6.4 I obtained the right result with lines that goes from one
multi-junction node to another.
This is strange because the code for v.net.components is identical in
6.4.2 and 6.5, also the code for the neta library used by this module.
