#1542: r.mapcalc
Reporter: malicera | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.2
Component: Default | Version: 6.4.2 RCs
Keywords: | Platform: MSWindows Vista
Cpu: x86-32 |
When I try to run an operation in r.mapcalc it fails.
I think there is a wrong path somewhere in the RC3, because it look for
some "C:/osgeo4w/..." which is not in my system.
In my computere I have also Qgis with grass 6.4.2RC2 which has no problem
with this operation.
The message in the command console is:
Settings: unable to get value 'workspace:posManager:enabled'
Settings: unable to get value 'workspace:posDisplay:enabled'
File "c:/osgeo4w/usr/src/grass-6.4.2RC3/dist.i686-pc-
mingw32/etc/wxpython/gui_modules/mcalc_builder.py", line
453, in OnMCalcRun
File "C:\Program Files\GRASS
6.4\etc\wxpython\gui_modules\goutput.py", line 521, in
RunCmd
task = menuform.GUI(show = None).ParseCommand(command)
mingw32/etc/wxpython/gui_modules/menuform.py", line 1732, in
ParseCommand
6.4\etc\python\grass\script\task.py", line 460, in
parse_interface
tree = etree.fromstring(get_interface_description(name))
6.4\Python25\lib\xml\etree\ElementTree.py", line 964, in XML
return parser.close()
6.4\Python25\lib\xml\etree\ElementTree.py", line 1254, in
close
self._parser.Parse("", 1) # end of data
xml.parsers.expat
ExpatError
no element found: line 1, column 0
Ticket URL: <http://trac.osgeo.org/grass/ticket/1542>
