[GRASS-dev] [GRASS GIS] #1567: Map display: saving image with scale and legend
Reporter: helena | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2 RCs
Keywords: | Platform: All
      Cpu: OSX/Intel |
when saving image from map display that includes scale and legend,
everything is saved correctly when the default setting is used,
but when a template (pre-set image size) is used scale and legend either
is not included
http://skagit.meas.ncsu.edu/~helena/grasswork/saveimg_test4.png
http://skagit.meas.ncsu.edu/~helena/grasswork/saveimg_test5.png
or it is not scaled properly.
See also
http://lists.osgeo.org/pipermail/grass-user/2011-November/062601.html
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/1567&gt;
      Cpu: OSX/Intel |
Comment(by hamish):
Replying to [ticket:1567 helena]:
fwiw,
barscale and legend on the display monitors are rendered using a fixed
number of pixels for height etc. They aren't designed to scale, they're
designed to be seen on a screen at the present resolution. try also
d.out.file with a command prompt driven Xmon.
for hardcopy output which scales well for posters or journal figures use
ps.map/try out the new Cartographic Composer; for web graphics and
screenshots I usually use `xwd` or the GIMP's screenshot tool.
Ideally the wxGUI would add legend and barscale commands into the layer
tree; you can get them to survive the export to a graphics file if you add
them manually there as command layers (hidden in the `Add grid of vector
labels overlay` drop down icon menu [any ideas on what to rename that
tooltip?]).
the current wxgui slippy overlay method always seemed a bit odd to me.
(but it mostly works)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1567#comment:1&gt;
Keywords: map display, decorations | Platform: All
      Cpu: OSX/Intel |
Changes (by annakrat):
  * keywords: => map display, decorations
Comment:
The decorations were rerendered (with the given size) but they weren't
used. Try r50721 in trunk, also backported to 6.5
Ticket URL: <http://trac.osgeo.org/grass/ticket/1567#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: map display, decorations
  Platform: All | Cpu: OSX/Intel
  * status: new => closed
  * resolution: => fixed
Comment:
The change is in all branches and seems to work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1567#comment:3&gt;
