#1568: 'make install' results in an installation dependent upon temporary build
directories
Reporter: helsene | Owner: grass-dev@…
Type: defect | Status: new
Component: Installation | Version: svn-trunk
Keywords: make install | Platform: Linux
Cpu: x86-64 |
Changes (by hamish):
* keywords: => make install
Comment:
Replying to [comment:2 helsene]:
> I've tried the README.debian instructions, they require some
> extra tinkering to get them going.
(hmm, works for me..)
> Installing per the instructions requires 'tcl' >=8.5, the
> dependency check fails even when 'tcl8.5-dev' is installed as
> the 'tcl' package either refers to 8.4 or is not installed.
> 'tcl' needs to be pulled from wheezy for the README.debian
> instructions to proceed; but that's a separate issue.
? both tcl8.4-dev and tcl8.5-dev are in all debians from lenny to sid. no
need to pull anything in from another version.
http://packages.debian.org/tcl8.4-dev
http://packages.debian.org/tcl8.5-dev
GRASS will work with either version, if you have one installed already you
can edit the debian/control file to match it.
anyway, tcl/tk can be switched off in grass7 without too many ill effects.
(the main one is you lose access to classic nviz)
> The 'debuild -i -uc -us -b' step in README.debian fails when
> it tries to run 'mkdir -p /usr/lib/bin' of all things.
> /usr/bin/make real-install
> make[2]: Entering directory `/home/helsene/src/g7_trunk'
> mkdir -p -m 755 /home/helsene/src/g7_trunk/debian/tmp/usr/lib/grass70
> mkdir -p -m 755 /usr/lib/bin
> mkdir: cannot create directory `/usr/lib/bin': Permission denied
> make[2]: *** [/usr/lib/bin] Error 1
> make[2]: Leaving directory `/home/helsene/src/g7_trunk'
> make[1]: *** [install] Error 2
> make[1]: Leaving directory `/home/helsene/src/g7_trunk'
> make: *** [install] Error 2
> dpkg-buildpackage: error: fakeroot debian/rules binary gave error exit
status 2
> debuild: fatal error at line 1325:
> dpkg-buildpackage -rfakeroot -D -us -uc -i -b failed
That is new to me and I don't understand the reason for it at all.
> So far, two methods of compiling 7.0 for a multi-user Debian
> Squeeze install are not working with the given instructions.
I build trunk all the time on a pretty vanilla squeeze, with no problems.
here's the build script I use:
(works on both grass 6.x and 7; change -march= to match your cpu model,
see the gcc man page for options; ./configure ignores any switch which
isn't relevant)
renice +17 -p $$
# AMD 64: -march=amdfam10
CFLAGS="-ggdb -march=amdfam10 -Wall -Werror-implicit-function-declaration"
./configure \
--with-tcltk-includes=/usr/include/tcl8.5 --with-cairo \
--with-motif --with-python=/usr/bin/python2.6-config \
--with-readline --with-cxx --with-odbc --with-sqlite \
--with-freetype --with-freetype-includes=/usr/include/freetype2 \
--without-postgres --with-proj-share=/usr/share/proj \
--enable-64bit --with-pthread -with-openmp \
--with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
--with-geos \
2>&1 | tee config_log.txt
time make -j 8
> This 'debuild' error should probably be split into its own
> ticket depending on where the error lies ('make real-install'
> or the debian packaging git repo's configs). I don't know enough
> about the install scripts to judge that.
I do a package build of 6.4.svn on sid fairly regularly (any time I/we
change the DebianGIS package files, and pre-release testing) and haven't
seen that. I've never tried to package grass/trunk though, so maybe
there's some patch it doesn't like.
can you run grass70 from the src/bin.x86_64-.../grass7 python script? if
so, try symlinking that into ~/bin/grass70
* you need to edit that python script to set LD_LIBRARY_PATH to the right
place. `make install` should do that for you (in the
/usr/local/grass7.0.svn installed copy). wrt your original problem,
perhaps that replacement is faulty?
for the real-install make target's sed substitution, see
trunk/include/Make/Install.make
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1568#comment:3>
