[GRASS-dev] [GRASS GIS] #1579: wingrass: errors while a DB is open results in a zombie dbf.exe
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Database | Version: svn-releasebranch64
Keywords: wingrass, db_driver | Platform: MSWindows XP
      Cpu: x86-32 |
Hi, moving this here from the later comments in #1276.
a G_fatal_error() while a db_driver is open, such as you get when you typo
the name of an attribute column, does not close the db driver, which is
left behind as a zombie process (along with a dependent cmd.exe). This is
a problem as the db driver may be holding a file open, blocking anything
else from working on it or removing it.
db_close_database_shutdown_driver() seems to shut it down properly.
work-around: ctrl-alt-del to the task manager and kill any dbf.exe
processes. the cmd.exe ones will then go away.
maybe this program helps: (lsof for Windows)
   http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs
/en-us/openfiles.mspx
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1579&gt;
      Cpu: x86-32 |
Comment(by neteler):
A few DBMI related backports have happened over the past few days,
still an issue? How to test it?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1579#comment:1&gt;
Priority: major | Milestone: 6.4.2
      Cpu: x86-32 |
Changes (by neteler):
  * priority: critical => major
Comment:
Apparently no longer an issue? Downgrading priority.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1579#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, db_driver, dbf
  Platform: MSWindows XP | Cpu: x86-32
  * keywords: wingrass, db_driver => wingrass, db_driver, dbf
  * status: new => closed
  * resolution: => fixed
Comment:
No response, closing. Feel free to reopen.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1579#comment:3&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: wingrass, db_driver, dbf
Changes (by mmetz):
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Replying to [comment:3 neteler]:
Reopened because the fundamental problem persists: subprocesses remain
open after the parent process was terminated. Applies to all branches.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1579#comment:4&gt;
Comment(by mmetz):
Replying to [comment:4 mmetz]:
Fixed in r62679-82 (all branches).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1579#comment:5&gt;
Changes (by martinl):
  * status: reopened => closed
Comment:
Replying to [comment:5 mmetz]:
Taking liberty to close the ticket. Feel free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1579#comment:6&gt;
