[GRASS-dev] [GRASS GIS] #1587: GRASS 7 manual: index.html not generated any more
Reporter: neteler | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Docs | Version: svn-trunk
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Due to some change the index.html is no longer generated.
Hence also the online manual is no longer easily accessible.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1587&gt;
      Cpu: Unspecified |
Comment(by glynn):
Replying to [ticket:1587 neteler]:
The change in question is r50817
Ticket URL: <http://trac.osgeo.org/grass/ticket/1587#comment:1&gt;
      Cpu: Unspecified |
Comment(by neteler):
Apparently I have incorrectly interpreted your suggestion:
On Wed, Feb 15, 2012 at 5:08 AM, Glynn Clements <glynn@gclements.plus.com>
wrote:
> Markus Neteler wrote:
>> * man: Indeed, also in my local compilation I don't have a man/
directory,
>> to be removed from the tar command?
> The manual pagers were moved from $GISBASE/man to $GISBASE/docs/man in
> r49908.
I have reverted r50817 in r50925. Hence the implications of r49908 are
unclear to me.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1587#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
I triggered the GRASS 7 compilation, now the manual is back:
http://grass.osgeo.org/grass70/manuals/html70_user/index.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/1587#comment:3&gt;
Comment(by glynn):
Replying to [comment:2 neteler]:
> Hence the implications of r49908 are unclear to me.
r49908 moved the destination directory for manual pages. It omitted a
necessary change for "make bindist" (which was fixed in r50818), but
appears to be otherwise complete. man/Makefile uses MANDIR which is
derived from MANBASEDIR which was changed in r49908, so doesn't require
any changes.
In spite of the name, the "man" directory in the GRASS source tree relates
mainly to the HTML manual pages. It contains the GRASS logo images, the
CSS stylesheet, and the Python scripts to build the various HTML indices.
Both the HTML-format and nroff-format manual pages are normally built from
the module's Makefile, although man/Makefile will generate any nroff-
format pages which are missing. Originally, the nroff-format manual pages
were all generated by man/Makefile, but adding it to the standard "html"
target ensures that any errors in the <module>.html file will show up if
the developer runs "make" in the module directory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1587#comment:4&gt;
