[GRASS-dev] [GRASS GIS] #1593: location wizard setting default extents broken
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: location wizard default extents | Platform: Unspecified
      Cpu: Unspecified |
Trying to set default extents in the location wizard raises this error:
2012-02-13 15:08:34.246 Python[15612:e0f] CFURLCreateWithString was passed
this invalid URL string:
'/System/Library/CoreServices/CommonCocoaPanels.bundle' (a file system
path instead of an URL string). The URL created will not work with most
file URL functions. CFURLCreateWithFileSystemPath or
CFURLCreateWithFileSystemPathRelativeToBase should be used instead.
   File
"/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/gis_set.py",
line 388, in OnWizard
     grassdatabase = self.tgisdbase.GetValue())
   File
"/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/location_wizard/wizard.py",
line 1806, in __init__
     defineRegion = RegionDef(self.parent, location = self.location)
   File
"/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc/gui/wxpython/location_wizard/dialogs.py",
line 102, in __init__
     key, val = line.split('=')
ValueError: too many values to unpack
Ticket URL: <http://trac.osgeo.org/grass/ticket/1593&gt;
Component: wxGUI | Version: svn-trunk
Keywords: location wizard, default extents | Platform: Unspecified
      Cpu: Unspecified |
Changes (by neteler):
  * keywords: location wizard default extents => location wizard, default
               extents
  * component: Default => wxGUI
Comment:
Michael, still an issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1593#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: needinfo, location wizard, default extents
  Platform: Unspecified | Cpu: Unspecified
  * keywords: location wizard, default extents => needinfo, location
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/grass/ticket/1593#comment:2&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: needinfo, location wizard, default extents
  * status: closed => reopened
  * resolution: fixed =>
Ticket URL: <http://trac.osgeo.org/grass/ticket/1593#comment:3&gt;
