#1620: cartographic composer doesn't work properly with vector data
Reporter: madi | Owner: grass-dev@…
Type: defect | Status: new
Component: Ps.map | Version: svn-trunk
Keywords: cartographic composer, ps.map | Platform: Linux
Cpu: x86-64 |
I get a strange behavior from the cartographic composer when I try to
print in the same canvas both rasters and vectors, in the ps file most of
the output is black, see attached image. No problem if I use only raster
maps.
Cpu: x86-64 |
Comment(by annakrat):
There's not enough information. Could you export the script for ps.map
module from the composer and run it with ps.map if the result is the same?
Also it could help to attach this script.
