#1625: Disk performance degrades by several orders of magnitude on two processes
Reporter: sprice | Owner: grass-dev@…
Type: defect | Status: new
Component: Default | Version: svn-trunk
Keywords: | Platform: MacOSX
Cpu: x86-64 |
When there are two GRASS process competing for a single disk on an I/O
bound task, performance doesn't just half. It decreases by several orders
of magnitude. However, 'iostat' lists just as much data flowing off the
disk as would be expected.
Also, when one task is canceled, the other process doesn't recover.
'iostat' claims that just as much data is flowing, but the remaining
process remains degraded until it is canceled and restarted.
I'd try to give a bit more debug info, but I suspect that it's some sort
of interaction with a caching layer in GRASS where extra data is read, and
then discarded, many times.
Cpu: x86-64 |
Comment(by sprice):
Actually, this might be a problem even when you have two processes each
accessing their own disk. The disk is pushing the maximum amount of data
again, but the processing is proceeding extremely slowly.
Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1625 sprice]:
of magnitude.
That's what I would expect, due to more time lost to seeking.
> However, 'iostat' lists just as much data flowing off the disk as would
be expected.
That isn't what I would expect for a normal GRASS command. The only
obvious case where I would expect that would be with in-memory
calculations which result in physical RAM availability being exceeded. In
that situation, memory would keep getting swapped out and back in again.
That is odd. Which commands, exactly?
Most GRASS raster commands just do sequential I/O. Any caching is internal
to the process; there isn't any interaction between processes.
Cpu: x86-64 |
Comment(by huhabla):
To assure that this issue is related to GRASS and not to your
implementation you to need to check the IO performance of a native GRASS
module running in parallel.
I have attached (multiproc_mapcalc.py) a simple grass module to check the
IO disk performance by running multiple instances of r.mapcalc in
parallel. The implementation assures disk syncing at the end of the
processing and measures the time between start and end of processing and
sync in seconds. I did not face large performance drops running multiple
r.mapcalc instances in parallel. Here some examples running on my AMD 6
core 1TB HD Ubuntu 64Bit system:
Running a single r.mapcalc instance to create a 50.000.000 cell integer
raster map:
GRASS 7.0.svn (TestLL):~/ > python multiproc_mapcalc.py base=raster
nprocs=1 size=50
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 80N
south: 0
west: 0
east: 62:30E
nsres: 0:00:36
ewres: 0:00:36
rows: 8000
cols: 6250
cells: 50000000
### main process ###
process id: 4152
### sub process for map <raster_0> ###
ppid 4152 pid 4158
100%
Sync disk
Time for processing: 3.885329 seconds
Removing raster <raster_0>
Running six r.mapcalc instance to create six 50.000.000 cell integer
raster maps:
nprocs=6 size=50
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 80N
south: 0
west: 0
east: 62:30E
nsres: 0:00:36
ewres: 0:00:36
rows: 8000
cols: 6250
cells: 50000000
process id: 4175
### sub process for map <raster_1> ###
ppid 4175 pid 4182
ppid 4175 pid 4181
### sub process for map <raster_2> ###
ppid 4175 pid 4183
### sub process for map <raster_3> ###
ppid 4175 pid 4186
### sub process for map <raster_4> ###
ppid 4175 pid 4187
### sub process for map <raster_5> ###
ppid 4175 pid 4190
100%
100%
100%
100%
100%
100%
Sync disk
Time for processing: 4.878238 seconds
Removing raster <raster_1>
Removing raster <raster_2>
Removing raster <raster_3>
Removing raster <raster_4>
Removing raster <raster_5>
