Have posted some weeks ago on a problem with the ODBC driver in the user
list
but got no answer until now. I am working on a master thesis and would
like
to use GRASS as the core of a solution with FOSGIS, but there seem to be
problems with the ODBC driver in GRASS for Windows. Beeing not a
programmer
I am not really sure about this and would like to consult the developers
of
GRASS for a suggestion how to proceed. Please correct me, if my point of
view should be wrong !
WARNING: Unable to open database <C:\dl\mdb\testinput.mdb> by driver
<odbc>
ERROR: Unable to open database
<$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db>
by driver <sqlite>
GRASS 7.0.svn> g.gisenv set=DEBUG=3
GRASS 7.0.svn> v.in.db driver=odbc database="C:\dl\mdb\testinput.mdb"
table=grassinput x=xcoor y=ycoor key=keyid out=vindb2
D2/3: dbDbmscap(): opendir
[C:\OSGeo4W\apps\grass\grass-7.0.svn\driver\db\]
D2/3: Vect_open_new(): name = vindb2
D1/3: Vect_set_thresh(): thresh = 0.000000
D1/3: V1_open_new_nat(): name = vindb2
D1/3: Vect_get_thresh(): thresh = 0.000000
D1/3: dig__write_head()
D1/3: write coor size (0) to head
D2/3: coor body offset 18
D3/3: dig_init_plus()
D3/3: dig_cidx_init()
D1/3: Vect_open_sidx(): name = vindb2 mapset= g7 mode = new
D1/3: Memory based spatial index
D2/3: G__read_Cell_head
D2/3: G__read_Cell_head_array
D3/3: region item: proj: 99
D3/3: region item: zone: 0
D3/3: region item: north: 228500
D3/3: region item: south: 215000
D3/3: region item: east: 645000
D3/3: region item: west: 630000
D3/3: region item: cols: 1500
D3/3: region item: rows: 1350
D3/3: region item: e-w resol: 10
D3/3: region item: n-s resol: 10
D3/3: region item: top: 1
D3/3: region item: bottom: 0
D3/3: region item: cols3: 1500
D3/3: region item: rows3: 1350
D3/3: region item: depths: 1
D3/3: region item: e-w resol3: 10
D3/3: region item: n-s resol3: 10
D3/3: region item: t-b resol: 1
D3/3: Vect_hist_command()
D3/3: G_recreate_command()
D1/3: Vect_default_field_info(): map = vindb2 field = 1
D2/3: drv = sqlite db = $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
D3/3: db_start_driver_open_database(): drvname='odbc',
dbname='C:\dl\mdb\testinput.mdb'
D3/3: win_spawn: args = C:\windows\system32\cmd.exe /c
"C:\OSGeo4W\apps\grass\grass-7.0.svn\driver\db\odbc.exe"
D1/3: db_d_init_error(): ODBC
<odbc>
by driver <sqlite>
GRASS 7.0.svn>
Replying to [comment:1 hellik]:
> tested with osgeo4w-wingrass7-nightly build and attached sample dataset
(DEBUG=3)
and also tested with osgeo4w-wingrass6.4.2
GRASS 6.4.2 (nc_spm_08)> g.gisenv set=DEBUG=3
GRASS 6.4.2 (nc_spm_08)> v.in.db driver=odbc
database="C:\dl\mdb\testinput.mdb" table=grassinput x=xcoor y=ycoor
key=keyid out=vindb5
D2/3: dbDbmscap(): opendir [C:\OSGeo4W\apps\grass\grass-6.4.2\driver\db\]
D2/3: Vect_open_new(): name = vindb5
D1/3: V1_open_new_nat(): name = vindb5
D2/3: coor body offset 14
D1/3: dig_spidx_init()
D1/3: Vect_default_field_info(): map = vindb5 field = 1
D2/3: drv = dbf db = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
drvname = odbc, dbname = C:\dl\mdb\testinput.mdb
"C:\OSGeo4W\apps\grass\grass-6.4.2\driver\db\odbc.exe"
DBMI-ODBC driver error: SQLConnect():
[Microsoft][ODBC Driver Manager] Der Datenquellenname wurde nicht
gefunden, und es wurde kein Standardtreiber angegeben (0)
WARNUNG: Kann die Datenbank <C:\dl\mdb\testinput.mdb> nicht mit dem
Treiber
<odbc> ÷ffnen.
FEHLER: Kann Datenbank <$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/> nicht mit
dem Treiber <dbf> ÷ffnen.
Replying to [comment:2 hellik]:
Treiber
> <odbc> ÷ffnen.
--------< Deutsche Verbindung >--------
DSN=Microsoft Access-
Datenbank;DBQ=t:\Datenbanken\Test.mdb;DefaultDir=t:\Datenbanken;DriverId=25;FIL=MS
Access;MaxBufferSize=2048;PageTimeout=5;
--------</ Deutsche Verbindung >--------
--------< alternative Zuweisung ohne DSN>--------
DBQ=t:\Datenbanken\Test.mdb;DefaultDir=t:\Datenbanken;Driver={Microsoft
Access-Treiber (*.mdb)};DriverId=25;FIL=MS
Access;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UserCommitSync=Yes;
--------</ alternative Zuweisung ohne DSN >--------
AFAIK, this is wrong usage of the odbc driver. database should not be the
path of the mdb file, but rather the name you give to the database in the
ODBC configuration.
This is what the message in German actually says:
"[Microsoft][ODBC Driver Manager] Der Datenquellenname wurde nicht
gefunden", i.e. The name of the source of data could not be found. Note
that it doesn't say that the _file_ hasn't been found, but the _name_.
ODBC is an intermediate layer which allows clients to communicate with
database in a standardized language. This means that clients do not
connect to the database directly, but via ODBC. In order to be able to
connect, you have to configure this connection using dedicated tools (IIUC
in MS Windows the tool is currently called "ODBC Data Source
Administrator") and give a name to that connection. You then use that name
as database name when accessing from a client via odbc.
I believe that unless there is more info about the ODBC access failing
when used correctly, this bug should be closed as invalid.
Replying to [comment:5 mlennert]:
As nothing has been posted since, I'm closing this bug as invalid.
