#1633: Unable to display shapefile attribute table due to pipe characters in dbf
field
Reporter: richardc | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Display | Version: 6.4.1
Keywords: | Platform: Linux
Cpu: Unspecified |
I'm receiving the following error on attempting to view the attribute
table of shapefiles in GRASS 6.4.1.2 (on Ubuntu Lucid):
item = layer, log = self.goutput)
File "/usr/lib/grass64/etc/wxpython/gui_modules/dbm.py",
line 653, in __init__
self.__createBrowsePage()
line 698, in __createBrowsePage
self.mapDBInfo, layer)
line 95, in __init__
keyColumn = self.LoadData(layer)
line 247, in LoadData
self.AddDataRow(i, record, columns, keyId)
line 286, in AddDataRow
if self.columns[columns[j]]['ctype'] != types.StringType:
IndexError
list index out of range
'''Method:'''
I import the shapefile as follows:
Layer Manager > File > Import vector data > Common import formats > Select
ESRI shapefile > Browse and select file > Import
And then select the layer in 'Layer Manager', and click on the 'Show
attribute table' icon. Then the error results
'Please wait loading attribute data..' with the following in the command
console -
IndexError
On closer inspection of the dbf file, some of the fields contain pipe
(i.e., '|') characters. On removing these the attribute table can be
displayed.
QGIS is able to display all data in the attribute table, including 'pipe'
characters.
Example of problem fields in single column named 'VARNAME_1,C,150':
VARNAME_1,C,150
Bangkok|Krung Thep|Krung Thep Maha Nakhon|Phra Nakhon-Thonburi
Buri Rum
Chaxerngsao|Pad Rew|Paed Riu|Petrieu|Shajeun Dhrao
Chainat
Chantaburi|Muang Chan
NOTE: issue posted originally at http://osgeo-org.1560.n6.nabble.com
/Index-error-Unable-to-show-attribute-table-of-shapefile-
tp4678952p4678952.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/1633>
