[GRASS-dev] [GRASS GIS] #1634: wingrass7: i.spectral -error
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Component: Imagery | Version: unspecified
Keywords: wingrass | Platform: MSWindows Vista
      Cpu: x86-32 |
tested with osgeo4w-wingrass7, nc-sample dataset:
gnuplot is in the path:
_path=C:\OSGeo4W\apps\Python27\Scripts
OSGEO4W home is C:\OSGeo4W
Der Befehl "manpath" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
Cleaning up temporary files...
Starting GRASS GIS...
WARNUNG: Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows
          nicht m÷glich.
           __________ ___ __________ _______________
          / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
         / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
        / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
        \____/_/ |_/_/ |_/____/____/ \____/___//____/
Welcome to GRASS 7.0.svn??GRASS homepage:
http://grass.
osgeo.org
This version running through: shell
(C:\OSGeo4W\apps\msys\bin\sh.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 7.0.svn> gnuplot
         G N U P L O T
         Version 4.6 patchlevel 0 last modified 2012-03-04
         Build System: MS-Windows 32 bit
         Copyright (C) 1986-1993, 1998, 2004, 2007-2012
         Thomas Williams, Colin Kelley and many others
         gnuplot home: http://www.gnuplot.info
         faq, bugs, etc: type "help FAQ"
         immediate help: type "help" (plot window: hit 'h')
gnuplot changed the codepage of this console from 850 to 1252 to
match the graph window. Some characters might only display correctly
if you change the font to a non-raster type.
Terminal type set to 'wxt'
gnuplot> exit
GRASS 7.0.svn>
adapted example from the manual:
http://grass.osgeo.org/grass70/manuals/html70_user/i.spectral.html
GRASS 7.0.svn> i.spectral.py raster=$LIST east_north=637502.25,221744.25
   File "C:/OSGeo4W/apps/grass/grass-7.0.svn/scripts/i.spectral.py", line
210, in
  <module>
     main()
205, in
  main
     draw_linegraph(what)
127, in
  draw_linegraph
     xf = file(xfile, 'w')
IOError: [Errno 13] Permission denied: 'data_x'
GRASS 7.0.svn> i.spectral.py -g raster=$LIST
210, in
  <module>
     main()
203, in
  main
     draw_gnuplot(what, xlabels, output, label)
76, in
draw_gnuplot
     outf = file(outfile, 'w')
IOError: [Errno 13] Permission denied: 'data_0'
GRASS 7.0.svn>
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1634&gt;
      Cpu: x86-32 |
Comment(by neteler):
The fix will be rather trivial: The command currently writes into
a non-accessible directory. Solution:
grass.tempdir() and os.path.join() must be used for the tmp files.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1634#comment:1&gt;
      Cpu: x86-32 |
Comment(by lucadelu):
Replying to [comment:1 neteler]:
I fixed this problem, so this ticket should be close. but i.spectral
doesn't work yet due to a bug in d.linegraph, please see #1842
Ticket URL: <http://trac.osgeo.org/grass/ticket/1634#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass
  Platform: MSWindows Vista | Cpu: x86-32
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Closing, missing part is in ticket #1842
Ticket URL: <http://trac.osgeo.org/grass/ticket/1634#comment:3&gt;
