[GRASS-dev] [GRASS GIS] #1635: allow r.los to run with a point vector layer as input for "coordinate identifying the viewing position"
Reporter: lutra | Owner: grass-dev@…
Priority: minor | Milestone: 6.4.3
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
This is my first feature request for GRASS.
It would be nice for modules like r.los (or even r.lake) to have the
option to interactively create a list of coordinates or even use a vector
point layer as input for "coordinate identifying the viewing position".
Ticket URL: <https://trac.osgeo.org/grass/ticket/1635&gt;
Component: Raster | Version: unspecified
Keywords: r.los, r.lake | Platform: All
      Cpu: All |
Changes (by hamish):
  * keywords: => r.los, r.lake
  * platform: Unspecified => All
  * component: Default => Raster
  * cpu: Unspecified => All
Comment:
as a work-around, you could try d.where in an xmon.
(Am I missing something, or is there no d.where-like coord query from the
wxGUI display canvas? either copy current cursor coord to the clipboard or
paste a list of them to the command output tab/window?)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1635#comment:1&gt;
Priority: minor | Milestone: 6.4.5
Component: Raster | Version: svn-releasebranch64
      Cpu: All |
Changes (by neteler):
  * version: unspecified => svn-releasebranch64
  * milestone: 6.4.3 => 6.4.5
Comment:
r.los, r.viewshed, etc. should be enhanced to support G_OPT_F_INPUT (file
input incl stdin)
for the "coordinates" parameter - like r.in.ascii for its input.
Then the wxGUI may also pipe in interactively.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1635#comment:2&gt;
Keywords: r.los, r.lake, r.viewshed | Platform: All
      Cpu: All |
Changes (by wenzeslaus):
  * keywords: r.los, r.lake => r.los, r.lake, r.viewshed
Comment:
In r58688, I changed `xy` to standard `coordinates` option which enables
to interactively pick coordinates from map display if you start G7:r.lake
from the main GUI command console, menu or module tree.
This partially fulfills the original request for interactivity. However,
there is no point in backporting this change as there is no standard
coordinates option in GRASS 6.4 and more importantly no mouse coordinates
picking from generated module forms/dialogs.
In trunk, G7:r.viewshed already has this standard coordinates option which
is supported by wxGUI. G7:r.los does not.
Neither of these three supports multiple coordinates input, although
G7:r.lake supports it using seed raster which makes more sense in this
case except for cases when you want to add just few points (e.g. 2). The
important thing is that supporting multiple coordinates goes far behind
supporting more inputs, probably algorithm itself needs to be improved to
fulfill the multiple point input required by the original request.
Separate tickets for each modules would be better in this case.
I'm not sure what is more advantageous, if `G_OPT_F_INPUT` or
`G_OPT_M_COORDS` with `multiple=yes` (I'm not sure how this is currently
supported by GUI). The later would create less fields in GUI and less
options. The former would partially replace `G_OPT_M_COORDS`, so there
would be no possibility to input coordinates interactively (I mean mouse
clicks on map, not writing the file content into dialog).
The solution would be to leave also the `G_OPT_M_COORDS` option (so in GUI
there would be 4 possible inputs for `r.lake`: 2 for file, 1 raster, 1
coordinates). The alternative to many input fields is to create a new
(GRASS) type `file with coordinates` which could recognized by GUI, so
that it would behave similarly to `G_OPT_M_COORDS`.
The vector point layer is also interesting but for `r.lake` it would
create 4th option how to input data (and vector could support also lines
and areas to make it even more complicated).
The GUI part of `G_OPT_M_COORDS` cannot be backported easily, so 6 and 7
would require different solutions to this problem, so I think that this
ticket cannot be solved for GRASS 6 but it would be nice to solve it for
trunk.
The only thing which might be possible to add to GRASS 6 wxGUI is the
right click on map which gives you possibility to copy coordinates pair.
Note that wxGUI does not care if the coordinates are inputted to module by
parameter or standard input, actually, standard input might be easier to
write. Note some modules in GRASS 7, mainly related to temporal framework,
which supports parameter and file to input multiple maps (for cases when
the number of maps is really large), for example see G7:r.colors.
''I know, this was long, sorry.''
Ticket URL: <https://trac.osgeo.org/grass/ticket/1635#comment:3&gt;
Keywords: r.los, r.lake, r.viewshed, wxGUI, forms, generated dialogs | Platform: All
      Cpu: All |
  * keywords: r.los, r.lake, r.viewshed => r.los, r.lake, r.viewshed,
Comment:
Current (timeline:2014-01-13T03:21) status in trunk:
  * G7:r.los uses `G_OPT_M_COORDS` (r58693)
  * G7:r.lake uses `G_OPT_M_COORDS` (r58688)
  * G7:r.viewshed uses `G_OPT_M_COORDS`
So, in the main GUI they have button to pick coordinates pair from map
display. I added note about G7:r.lake and G7:r.los changes to
wiki:Grass7/NewFeatures.
The r58692 commit for trunk enables faster usage of coordinates copied
from map display or `d.mon wx0` (comma (`583,2715`) is used instead of
semicolon (`583;2715`)). It might be possible to backport this trunk-only
feature (the current change is trivial but the feature itself is not in
GRASS 6).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1635#comment:4&gt;
For the record: I check (hopefully) all other GRASS 7 modules, here
the remaining candidates for update to use G_OPT_M_COORDS:
* display/d.profile/main.c (maybe)
* misc/m.transform/main.c (maybe)
* raster/r.circle/main.c
* raster/r.horizon/main.c
      Cpu: All |
Comment(by neteler):
Ticket URL: <https://trac.osgeo.org/grass/ticket/1635#comment:5&gt;
