#1654: v.extract: allow direct transformation of centroids to polygons
Reporter: mlennert | Owner: grass-dev@…
Component: Default | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
A recurrent task is to extract centroids from polygons and to use them as
points in further analysis. Currently, one has to do this in two steps:
v.extract in=polygonmap out=centroidmap type=centroid
v.type in=centroidmap out=pointmap type=centroid,point
As this is IMHO such a basic operation, it would be great if v.extract
could directly create a point layer. This could be implemented in
different ways (in my order of preference):
1) If map contains polygons, but no points and type=point is given, then
extract the centroids as points, if type=centroid extract as centroids.
2) If type=centroid is given, extract as points by default, but allow to
extract as centroids by use of a flag
3) If type=centroid is given, extract as centroids by default, but allow
to extract as points by use of a flag
A problem obviously might occur if a map contains a mix of polygons and
points...
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1654>
