[GRASS-dev] [GRASS GIS] #1655: problem compiling r.terraflow with g++ 4.7.0
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Compiling | Version: 6.4.2
Keywords: r.terraflow, libiostream | Platform: Linux
      Cpu: x86-64 |
for 6.4.2 on Debian/sid we're getting the following fail to builds:
Errors in:
/home/hamish/dev/grass/git/grass/lib/iostream
/home/hamish/dev/grass/git/grass/raster/r.terraflow
lib/iostream is fixed by backporting r50130.
r.terraflow still fails with a number of "'foo' was not declared in this
scope, and no declarations were found by argument-dependent lookup at the
point of instantiation [-fpermissive]":
.../raster/r.terraflow$ make
mkdir -p OBJ.x86_64-pc-linux-gnu/FLOAT
c++ -c -I/home/hamish/dev/grass/git/grass/dist.x86_64-pc-linux-gnu/include
-g -O2 -DUSER=\"hamish\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT main.cc -o OBJ.x86_64-pc-linux-
gnu/FLOAT/main.o
In file included from /home/hamish/dev/grass/git/grass/dist.x86_64-pc-
linux-gnu/include/grass/iostream/empq_adaptive_impl.h:30:0,
linux-gnu/include/grass/iostream/ami.h:41,
                  from common.h:27,
                  from main.cc:39:
gnu/include/grass/iostream/empq_adaptive.h: In constructor
'EMPQueueAdaptive<T, Key>::EMPQueueAdaptive(long int)':
gnu/include/grass/iostream/empq_adaptive.h:53:47: warning: delegating
constructors only available with -std=c++11 or -std=gnu++11 [enabled by
default]
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT common.cc -o OBJ.x86_64-pc-linux-
gnu/FLOAT/common.o
                  from common.h:27,
                  from common.cc:35:
default]
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT stats.cc -o OBJ.x86_64-pc-linux-
gnu/FLOAT/stats.o
                  from stats.h:29,
                  from stats.cc:30:
default]
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT fill.cc -o OBJ.x86_64-pc-linux-
gnu/FLOAT/fill.o
                  from fill.h:22,
                  from fill.cc:24:
default]
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT types.cc -o OBJ.x86_64-pc-linux-
gnu/FLOAT/types.o
-DPACKAGE=\""grassmods"\" -DELEV_FLOAT ccforest.cc -o OBJ.x86_64-pc-linux-
gnu/FLOAT/ccforest.o
                  from ccforest.h:27,
                  from ccforest.cc:19:
delegatinghamish@sid-amd64-vm:~/dev/grass/git/grass/raster/r.terraflow$
make
gnu/FLOAT/main.o
                  from common.h:27,
                  from main.cc:39:
default]
gnu/FLOAT/common.o
                  from common.h:27,
                  from common.cc:35:
default]
gnu/FLOAT/stats.o
                  from stats.h:29,
                  from stats.cc:30:
default]
gnu/FLOAT/fill.o
                  from fill.h:22,
                  from fill.cc:24:
default]
gnu/FLOAT/types.o
                  from ccforest.h:27,
default]
linux-gnu/include/grass/iostream/empq.h:35:0,
linux-gnu/include/grass/iostream/empq_impl.h:26,
linux-gnu/include/grass/iostream/ami.h:39,
                  from ccforest.h:27,
gnu/include/grass/iostream/minmaxheap.h: In instantiation of 'HeapIndex
MinMaxHeap<T>::fill(T*, HeapIndex) [with T = keyvalue<int>; HeapIndex =
unsigned int]':
gnu/include/grass/iostream/empq_impl.h:674:67: required from 'bool
em_pqueue<T, Key>::min(T&) [with T = keyvalue<int>; Key = int]'
gnu/include/grass/iostream/empq_adaptive_impl.h:237:2: required from
'bool EMPQueueAdaptive<T, Key>::min(T&) [with T = keyvalue<int>; Key =
int]'
ccforest.cc:164:4: required from 'void ccforest<T>::findAllRoots(int)
[with T = int]'
ccforest.cc:340:16: required from here
gnu/include/grass/iostream/minmaxheap.h:747:5: error: 'insert' was not
declared in this scope, and no declarations were found by argument-
dependent lookup at the point of instantiation [-fpermissive]
gnu/include/grass/iostream/minmaxheap.h:747:5: note: declarations in
dependent base 'BasicMinMaxHeap<keyvalue<int> >' are not found by
unqualified lookup
gnu/include/grass/iostream/minmaxheap.h:747:5: note: use 'this->insert'
instead
gnu/include/grass/iostream/minmaxheap.h: In instantiation of 'void
UnboundedMinMaxHeap<T>::grow() [with T = keyvalue<int>]':
ccforest.cc:340:38: required from here
gnu/include/grass/iostream/minmaxheap.h:780:2: error: 'allocateHeap' was
not declared in this scope, and no declarations were found by argument-
gnu/include/grass/iostream/minmaxheap.h:780:2: note: declarations in
unqualified lookup
gnu/include/grass/iostream/minmaxheap.h:780:2: note: use
'this->allocateHeap' instead
gnu/include/grass/iostream/minmaxheap.h:786:2: error: 'freeHeap' was not
gnu/include/grass/iostream/minmaxheap.h:786:2: note: declarations in
unqualified lookup
gnu/include/grass/iostream/minmaxheap.h:786:2: note: use 'this->freeHeap'
instead
make: *** [OBJ.x86_64-pc-linux-gnu/FLOAT/ccforest.o] Error 1
  * Debian's gcc 4.7.0-8
  * Debian's eglibc 2.13-32
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1655&gt;
      Cpu: x86-64 |
Comment(by hamish):
as suggested by the error message, adding "this->" before 'insert',
'allocateHeap', and 'freeHeap' allowed it to compile.
interestingly it was taking the header file from dist.*/include/ not
include/, so I had to edit both to get it to take.
any comments before committing the change? (I'm no C++ expert, just monkey
see-monkey do in this case)
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1655#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
diff --git a/include/iostream/minmaxheap.h b/include/iostream/minmaxheap.h
index c3d057a..4991c22 100644
--- a/include/iostream/minmaxheap.h
+++ b/include/iostream/minmaxheap.h
@@ -744,7 +744,7 @@ HeapIndex MinMaxHeap<T>::fill(T* arr, HeapIndex n) {
    //heap must be empty
    assert(this->size()==0);
    for (i = 0; !full() && i<n; i++) {
- insert(arr[i]);
+ this->insert(arr[i]);
    if (i < n) {
      assert(i == this->maxsize);
@@ -777,13 +777,13 @@ void UnboundedMinMaxHeap<T>::grow() {
    if(old) {
         HeapIndex n = this->size();
- this->A = allocateHeap(this->maxsize); /* allocate a new array */
+ this->A = this->allocateHeap(this->maxsize); /* allocate a new
array */
         /* copy over the old values */
         assert(this->maxsize > n);
         for(HeapIndex i=0; i<=n; i++) { /* why extra value? -RW */
           this->A[i] = old[i];
- freeHeap(old); /* free up old storage */
+ this->freeHeap(old); /* free up old storage */
Ticket URL: <http://trac.osgeo.org/grass/ticket/1655#comment:2&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [comment:1 hamish]:
It looks fine to me.
FWIW, [http://gcc.gnu.org/bugzilla/show_bug.cgi?id=24163 this] gcc bug
allowed it to compile in older versions, but that has apparently been
fixed in 4.7.0.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1655#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.terraflow, libiostream
  Platform: Linux | Cpu: x86-64
Changes (by hamish):
  * status: new => closed
  * resolution: => fixed
Comment:
committed to trunk with r51633, and backported (along with r50130) to
devbr6 and relbr64.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1655#comment:4&gt;
