[GRASS-dev] [GRASS GIS] #1658: g.rename, g.copy do not ask for --overwrite, they just do it
Reporter: hamish | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 6.5.0
Component: Default | Version: svn-develbranch6
Keywords: g.rename, g.copy, overwrite | Platform: Linux
      Cpu: x86-64 |
discovered in devbr6, but may happen in other branches too:
G65> r.mapcalc one=1
  100%
G65> r.mapcalc two=2
  100%
G65> g.rename one,two
Rename raster <one> to <two>
G65> r.info -r two
min=1
max=1
G65> echo $GRASS_OVERWRITE
G65> r.mapcalc three=3
  100%
G65> g.copy three,two
Copy raster <three@user1> to current mapset as <two>
G65> r.info -r two
min=3
max=3
I just lost a map :frowning:
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1658&gt;
      Cpu: x86-64 |
Comment(by glynn):
Replying to [ticket:1658 hamish]:
In 7.0 SVN:
$ g.rename one,two
<two> already exists in mapset <glynn>
In 6.5, g.copy etc have the same logic (checking module->overwrite), but
it doesn't work correctly with 6.5's G_parser(), which needs
         module_info.overwrite = 0;
at the beginning of the check_overwrite() function.
The overwrite field of the GModule structure serves two purposes:
1. If it is set by the module prior to calling G_parser(), the --o flag
will be listed in the --help (etc) output even if no options have "new" in
the gisprompt field. This is required for modules such as g.copy and
r.mapcalc which have output maps specified by means other than "output="
options.
2. It is set by G_parser() if the --o or --overwrite options were given,
the GRASS variable OVERWRITE is set to a non-zero value, or the
environment variable GRASS_OVERWRITE is set to a non-zero value.
In 7.0, G_parser() explicitly sets it to zero if --help or similar aren't
being used. 6.x doesn't do this, so setting it before calling G_parser()
to indicate that --o is accepted will result in it always being set upon
return from G_parser().
Ticket URL: <https://trac.osgeo.org/grass/ticket/1658#comment:1&gt;
      Cpu: x86-64 |
Comment(by hamish):
see also #767
Ticket URL: <http://trac.osgeo.org/grass/ticket/1658#comment:2&gt;
      Cpu: x86-64 |
Comment(by wenzeslaus):
Please, have a look at a test for `g.rename` in version 7 (trunk) and add
cases which you think are missing:
  * source:trunk/general/g.rename/testsuite
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2015-02-15-08-00/report_for_nc_spm_08_grass7_nc/general/g.rename/test_overwrite/index.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/1658#comment:3&gt;
