[GRASS-dev] [GRASS GIS] #1662: Caching bug in 3D raster library with large data
Reporter: huhabla | Owner: grass-dev@…
     Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: Raster3D | Version: svn-trunk
Keywords: 3D raster, tiles, cache | Platform: Linux
      Cpu: x86-32 |
There is a strange bug that appeared on an Intel Atom netbook while
converting a list of raster maps into a 3D raster map. Operating system is
a 32 Bit Ubuntu linux:
GRASS 7.0.svn (etopo_epsg4326): t.rast.to.rast3 input=temptest
output=temptest
  100%
Creating 3D raster map
ERROR: Rast3d_cache_hash_remove_name: name not in hashtable
ERROR: Unable to create raster3d map <temptest>
GRASS 7.0.svn (etopo_epsg4326): g.region -p3
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 90N
south: 90S
west: 180W
east: 180E
top: 20.00000000
bottom: 0.00000000
nsres: 0:02
nsres3: 0:02
ewres: 0:02
ewres3: 0:02
tbres: 1
rows: 5400
rows3: 5400
cols: 10800
cols3: 10800
depths: 20
cells: 58320000
cells3: 1166400000
I can not reproduce this bug on my 64Bit machine, since i have no 32Bit
Linux available, it would be great if somebody with a 32Bit Linux can
reproduce this.
Best
Soeren
Ticket URL: <http://trac.osgeo.org/grass/ticket/1662&gt;
      Cpu: x86-32 |
Comment(by neteler):
Could you please provide the "etopo_epsg4326" location which includes
the temptest map?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1662#comment:1&gt;
      Cpu: x86-32 |
Comment(by mlennert):
Could you provide the data ?
Can anyone else confirm this ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1662#comment:2&gt;
      Cpu: x86-32 |
Comment(by huhabla):
The test case for this error has been integrated in the raster3d unit test
suite:
test.g3d.lib unit=large
The raster3d test suite must be compiled by hand. Simply switch into the
lib/raster3d/test directory and type make. A new module will be created
with the name "test.g3d.lib".
GRASS 7.0.svn
(nc_spm_08_grass7):~/src/grass7.0/grass_trunk/lib/raster3d/test >
test.g3d.lib help
Description:
  Performs unit and integration tests for the g3d library
Usage:
  test.g3d.lib [-uial] [unit=string] [integration=string] [depths=value]
    [rows=value] [cols=value] [tile_size=value] [--verbose] [--quiet]
Flags:
   -u Run all unit tests
   -i Run all integration tests
   -a Run all unit and integration tests
   -l Switch zip compression on
  --v Verbose module output
  --q Quiet module output
Parameters:
          unit Choose the unit tests to run
                 options: coord,putget,large
   integration Choose the integration tests to run
                 options:
        depths The number of depths to be used for the large file put/get
value test
                 default: 20
          rows The number of rows to be used for the large file put/get
value test
                 default: 5400
          cols The number of columns to be used for the large file
put/get value test
                 default: 10800
     tile_size The tile size in kilo bytes to be used for the large file
put/get value test. Set the tile size to 2048 and the number of
row*cols*depths > 130000 to reproduce the tile rle error.
                 default: 32
I have no 32Bit Linux system to test this issue, but i think it is related
to the 32Bit address space of the operating system and therefore not a
bug.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1662#comment:3&gt;
      Cpu: x86-32 |
Comment(by annakrat):
I tested it on 32Bit Ubuntu and I get a segmentation fault after 100% is
finished. Should I test something else?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1662#comment:4&gt;
Sorry for replying directly to the list, but the grass trac server
seems to be down or very, very busy.
Replying to [comment:4 annakrat]:
I tested it on 32Bit Ubuntu and I get a segmentation fault after 100% is finished. Should I test something else?
Many thanks for the test.
Can you please run the test in the gnu debugger (gdb) again, so that i
can get an idea of what the reason for the segfault is? You can
create a backtrace after the segfault occurred with "bt" in the gdb
session.
Example:
gdb test.g3d.lib
r unit=large
..... segfault
bt
Can you then please provide the output of the backtrace command "bt"?
2013/8/26 GRASS GIS <trac@osgeo.org>:
      Cpu: x86-32 |
      Cpu: x86-32 |
Here is the backtrace:
#0 0xb7f7c3ac in Rast3d_cache_hash_name2index (h=0x8051f98,
name=1715470336) at cachehash.c:114
#1 0xb7f7adf7 in Rast3d_cache_elt_ptr (c=0x805a0f0, name=1715470336) at
cache1.c:469
#2 0xb7f7b04c in Rast3d_cache_load (c=0x805a0f0, name=1715470336) at
cache1.c:517
#3 0xb7f7c08b in Rast3d_flush_all_tiles (map=0x8054028) at cache.c:310
#4 0x0804bd57 in test_large_file_random (depths=20, rows=5400,
cols=10800, tile_size=32) at test_put_get_value_large_file.c:283
#5 0x0804b421 in unit_test_put_get_value_large_file (depths=20,
rows=5400, cols=10800, tile_size=32) at test_put_get_value_large_file.c:39
#6 0x08049c34 in main (argc=2, argv=0xbfffedd4) at test_main.c:160
Thank you for the instructions, here they are for completeness:
gdb test.g3d.lib
r unit=large
..... segfault
bt
Ticket URL: <http://trac.osgeo.org/grass/ticket/1662#comment:5&gt;
      Cpu: x86-32 |
Many thanks for the backtrace Anna. I was able to reproduce this behavior
with my shiny "new" 32Bit Atom Netbook.
The problem is that the cache file accessed in cache.c line 310 gets wrong
so that a corrupted
tile index is read from the file. This index is much to large for the tile
array accessed in cachehash.c line 114,
hence crash because of memory violation.
The cache file is corrupted because it exceedes the 32Bit limit of 4GB,
hence the computed offset in cache.c
faces a number overrun, resulting in a wrong file offsets. The size of
size_t and off_t is 4 Bytes on my 32 Bit system
and therefore not suited for files larger than 4GB.
IMHO its a problem of the 32Bit operating system. I don't know how to
solve this issue ... LFS?? Any suggestions?
Conclusion: raster3D maps with more than a billion cells in case of type
float, or more than 500 million cells in case
of type double are not supported on 32Bit systems.
Replying to [comment:5 annakrat]:
cache1.c:469
cache1.c:517
> gdb test.g3d.lib
> r unit=large
> ..... segfault
> bt
Ticket URL: <http://trac.osgeo.org/grass/ticket/1662#comment:6&gt;
      Cpu: x86-32 |
Replying to [comment:6 huhabla]:
So does that mean this is a wontfix bug that should go into known issues ?
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/1662#comment:7&gt;
      Cpu: x86-32 |
Comment(by hamish):
I see many times "long"* is used as a variable type in lib/raster3D/,
e.g.:
(* and some "unsigned long" too)
index.c: long indexLast;
index.c: indexLast = lseek(map->data_fd, (long)0, SEEK_END);
so to make it LFS compatible on 32bit those having to do with file offsets
and cell counts should be changed to e.g. off_t or use a G_*() wrapper
instead? (none for lseek(), but we do have G_ftell() and G_fseek())
fixable! :slight_smile:
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1662#comment:8&gt;
      Cpu: x86-32 |
Comment(by hamish):
lib/raster3D/
for the record:
NAME
        lseek - reposition read/write file offset
SYNOPSIS
        #include <sys/types.h>
        #include <unistd.h>
        off_t lseek(int fd, off_t offset, int whence);
Ticket URL: <https://trac.osgeo.org/grass/ticket/1662#comment:9&gt;
      Cpu: x86-32 |
Comment(by glynn):
Replying to [comment:8 hamish]:
e.g.:
Historically, most of my "bulk" fixes for things like LFS skipped over the
raster3D library (because the number of cases in raster3D often exceeded
those in the rest of the GRASS code base combined).
offsets and cell counts should be changed to e.g. off_t or use a G_*()
wrapper instead? (none for lseek(), but we do have G_ftell() and
G_fseek())
File offsets should use off_t.
Cell counts ... are a problem. "long long" and "int64_t" aren't in C89,
"long" is only 32 bits on 64-bit Windows, size_t is unsigned.
Windows itself doesn't have off_t (or fseeko/ftello). The POSIX functions
in MSVCRT use either int (e.g. read, write) or long (e.g. lseek). Some of
them have 64-bit variants using !__int64 (e.g. _lseeki64, although the
name has changed between MSVCRT versions).
Ticket URL: <https://trac.osgeo.org/grass/ticket/1662#comment:10&gt;
