#1666: v.proj - Error in pj_do_transform
Reporter: spiderplant0 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: MSWindows 7
Cpu: x86-64 |
Consider this data organization...
e:\work\grass\GB\mapset1
e:\work\grass\UK_EPSG900913\mapset1
I.e. 'mapset1' folders contain the 'vector' and 'dbf' directories etc.
And I have two locations 'GB' and 'UK_EPSG900913' The projections are set
to OSGB36 and epsg900913 respectively.
I have a map in the 'GB' location that I wish to re-project to epsg900913.
So I choose the location as 'UK_EPSG900913' and 'mapset1' and then I run
this command...
v.proj input=scot location=GB mapset=mapset1 output=scot1
It works on Linux but when I run this on windows I get the error...
Reprojecting primitives:
pj_transform() failed: failed to load datum shift file
ERROR: Error in pj_do_transform
Tested on..[[BR]]
Windows 7 64-bit with GRASS 6.4.2 32-bit - get error[[BR]]
Ubuntu 12.04 64-bit with GRASS 6.4.2 64-bit - OK[[BR]]
Ubuntu 11.10 32-bit with GRASS 6.4.1 32-bit - OK[[BR]]
Ticket URL: <https://trac.osgeo.org/grass/ticket/1666>
