[GRASS-dev] [GRASS GIS] #1667: xref and yref have no effect in d.vect labels in GRASS 7
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Component: Display | Version: unspecified
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
Changing xref and yref do not affect the label positioning. No error, just
no effect. Labels are placed below and to the right of points in all
cases, regardless of xref and yref settings. This is OSX but probably
affects other OS as well.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1667&gt;
Keywords: | Platform: MSWindows CygWin
      Cpu: Unspecified |
Changes (by mlennert):
  * platform: Unspecified => MSWindows CygWin
Comment:
Replying to [ticket:1667 cmbarton]:
just no effect. Labels are placed below and to the right of points in all
I cannot confirm this with a fresh checkout of trunk on Debian GNU/Linux.
Label positioning works perfectly here.
Marking this as platform-specific for now.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1667#comment:1&gt;
Keywords: | Platform: MacOSX
      Cpu: Unspecified |
Changes (by cmbarton):
  * platform: MSWindows CygWin => MacOSX
Comment:
I'm on a Mac, so I am switching the platform to that, since I can't say
that it doesn't work in Windows. Are you doing this through the GUI?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1667#comment:2&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:2 cmbarton]:
Sorry, meant to set MacOSX, must have been distracted.
Both in the GUI and on CLI with d.mon start=png.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1667#comment:3&gt;
      Cpu: Unspecified |
Comment(by cmbarton):
OK. I was doing it through the GUI only, but could see that the correct
command was being constructed. Just a thought, perhaps this does not work
in a LatLon region?
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1667#comment:4&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords:
  Platform: MacOSX | Cpu: Unspecified
  * status: new => closed
  * resolution: => invalid
Comment:
I just tried it again in Spearfish and then in the LatLong location again
and it worked. I guess I'll chalk this up to to one of those mysterious
errors and mark it as invalid. If I can cause it to happen consistently,
I'll reopen
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/1667#comment:5&gt;
