#1668: r.regression.line F-test incorrect
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Component: Raster | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
One of my students noticed that the "F-test" in r.regression.line does not
seem to be calculating F, but instead calculating -(R squared).
For example, from the Spearfish demo data,
r.regression.line map1=elevation.dem@PERMANENT map2=slope@PERMANENT
y = a + b*x
a (Offset): -16.675093
b (Gain): 0.020833
R (sumXY - sumX*sumY/N): 0.481666
N (Number of elements): 2611107
F (F-test significance): -0.232002
meanX (Mean of map1): 1353.724982
sdX (Standard deviation of map1): 176.754565
meanY (Mean of map2): 11.527723
sdY (Standard deviation of map2): 7.645157
0.481666^2 = 0.232002
I haven't checked, but this probably affects all versions of GRASS
Replying to [ticket:1668 cmbarton]:
not seem to be calculating F, but instead calculating -(R squared).
> y = a + b*x
> b (Gain): 0.020833
The values only seem the same because of rounding.
However, the formula for calculating the statistic does not seem correct
in the code. IIUC, instead of
These DO give VERY different values. For slope vs. elevation in my
Spearfish example, the current equation gives a value of -0.2320019531,
while the revised equation gives a value of 1.02410689008565E-006.
Replying to [comment:2 cmbarton]:
> http://www.weibull.com/DOEWeb/hypothesis_tests_in_simple_linear_regression.htm
defines
> F = SumSq Regression /( SumSq Errors / (count - 2))
Yup, sorry, in my proposal another set of parentheses was missing. It
should be:
F = R * R / ((1 - R * R) / (count - 2));
where
R*R = SumSq Regression
1-R*R = SumSq Errors
which in your example gives you a value for F = 788781, i.e. a probability
that there is a relationship so close to one that most software will
probably just give you 1 after rounding.
Again, I can commit this, but would like to have someone more versed in
statistics confirm.
Replying to [comment:3 mlennert]:
defines
should be:
> where
probability that there is a relationship so close to one that most
software will probably just give you 1 after rounding.
statistics confirm.
You can compare to the grass7 addon r.regression.multi whose results are
identical to those of R.
Replying to [comment:4 mmetz]:
This is what I did and actually r.regression.line with the above change
gives the same result as R, not r.regression.multi (regressing the landsat
bands 10 and 20 from the NC data set):
F (R): 6268922
F (r.regression.line with change): 6268922.212939
F (r.regression.multi): 6268947.256273
I think I've found the problem in r.regression.multi:
I've just committed a fix for r.regression.line to trunk, grass65 and
grass64_release. I'll leave it up to Markus to decide whether my fix for
r.regression.multi is the right one.
Replying to [comment:6 mlennert]:
Your fix for r.regression.multi seems correct. Apparently I have only
validated the F values for the predictors against R, not the global F.
Fixed in r51906.
