#167: g.region: reports wrong center longitude and LL bounding box
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.6
Component: Default | Version: svn-develbranch6
Resolution: | Keywords: g.region 180
Changes (by mmetz):
* platform: => Unspecified
* cpu: => Unspecified
Comment:
These calculations can not be performed with longitudes wrapped to [-180,
180], fixed in trunk r70671.
`g.region -l` (Print the current region in lat/long using the current
ellipsoid/datum) prints the corners and now also the center of the current
region projected to lat/long.
`g.region -b` (Print the maximum bounding box in lat/long on WGS84) now
tries to estimate the maximum bounding box based not only on the corners
but also on the boundaries using the resolution of the current region. The
result is a more realistic bounding box in lat/long. The reported center
coordinates are the center coordinates of the lat/long box, not of the
current window.
`g.region -n` (Print the convergence angle (degrees CCW). The difference
between the projection's grid north and true north, measured at the center
coordinates of the current region.) is now using the center coordinates of
the current region projected to lat/long.
Ticket URL: <https://trac.osgeo.org/grass/ticket/167#comment:3>
